Bathroom Exhaust Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 09:14 AM   #1
Rewards Points: 968
Question
Bathroom exhaust fan
Not sure if this is the best section, but as some of you may know I recently demoed my ceiling. Upon doing so I discovered that the exhaust fan in the bathroom does not vent to the outside! So my question is what would be the easier solution:
make a hole through the shingled roof or run it sideways under the roof decking out through fascia board? thanks for input!
federer is offline   Reply With Quote
Old 02-22-2011, 09:15 AM   #2
Coatings Nerd
All of the vents in my home are through the side, not the roof.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-22-2011, 09:38 AM   #3
Rewards Points: 968
thanks for the input-where did you put the holes in the side?
Old 02-22-2011, 09:41 AM   #4
Coatings Nerd
They both come out under the overhangs, on the side of the house.
Old 02-23-2011, 03:01 PM   #5
Registered User
Rewards Points: 526
Be aware, fan termination near any attic intake vents in the soffit will bring the moisture back in to the attic condensing on the roof framing and/or insulation. If no intakes at soffits, the exhaust will also get the soffit dirtier faster from the moisture condensing after being forced upward from the positive wind coming up the wall of the house. A minor worry unless two-story... Gable wall is ideal.
Gary
Old 03-05-2011, 09:30 AM   #6
Rewards Points: 968
Gary
thanks Gary. there is no intake at the soffit. why would 2 story resolve this issue? this is for the upstairs bathroom.
Using Bathroom Exhaust During Demo DetroitEE Building & Construction 10 01-17-2011 02:32 PM
Can bathroom exhaust and dryer share same outside duct? benze HVAC 17 09-08-2010 02:24 PM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 03:09 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
