Bathroom Exhaust Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 02:20 AM   #1
Rewards Points: 248
Not sure if this is the correct section for this question, but I figure someone will know.
I want to put a bathroom exhaust fan in the basement bathroom. But the bathroom is in the basement and the outside wall is cement. So I don't want a direct wall exhaust fan. I want a ceiling exhaust fan, but can I cut a hole in the wood where the floor joist connect to? It would be a 3" or 4" cut.
Thanks in advance.
jburchill is offline   Reply With Quote
Old 11-26-2011, 02:47 AM   #2
What is the dimension of the rim joist. If it's a 2x6, you probably don't want to drill a 4" hole. It's not exactly going to bring the house down but try to keep it in the center of the bay. Also take note of what is sitting on top of that area to make sure that any needed loads are carried properly.
Evstarr is offline   Reply With Quote
Old 11-26-2011, 08:51 AM   #3
Rewards Points: 582
how big is fan that will determine exhaust pipe size evstarr makes good point and agree won't bring down house but don't ask for trouble down the road....what is size of bath also will tell us how many cfm needed...
Old 11-26-2011, 01:37 PM   #4
Rewards Points: 87
What's your plan for getting the exhaust outside the house?
huesmann is offline   Reply With Quote
Old 11-26-2011, 07:04 PM   #5
Rewards Points: 248
Well the plan would be to cut a hole in the wall and run the duct work to the fan. It would only be like 2 feet of duct work. I will probably have a friend do the work, he works for company that does this type of work so he knows what he'd be doing.
I was just wondering if I could cut through the rim joist for the exhaust vent.
Now that I think of it, the vent for our dryer and the vent to our furnace goes through the rim joist. Just wasn't thinking.
Old 11-26-2011, 09:59 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The "furnace" - REALLY?
Now there's a scary thought!
Old 11-26-2011, 11:08 PM   #7
Registered User
Rewards Points: 5,216
http://docs.google.com/viewer?a=v&q=...ECbKWbauhW_uAQ
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
jburchill (11-27-2011)
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 08:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
