Bathroom Ceiling Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2009, 10:51 AM   #1
Before I get started I wanted to make sure I'm installing the sheetrock on my bathroom ceiling correctly. The ceiling is 24" OC and I'm going to use 5/8" sheetrock. From earlier posting I've decided not to use greenboard on the ceiling because it's less rigid and be more likely to sag. There is an exhaust fan in the bathroom
I also understand that I don't have to run strips perpendicular to the rafters because I'm using 5/8 sheetrock.
Can you confirm what I'm doing before I get started?
MikeyP is offline   Reply With Quote
Old 04-25-2009, 04:01 PM   #2
Remodeling Contractor
This will work fine. I would suggest using Zinsser's Perma White paint to finish this ceiling. You can tint it to any color. But as a self priming solution you will get active fungicide in all three coats allowing a much longer protection period to prevent mold.
Old 04-25-2009, 06:03 PM   #3
Drywall contractor
Rewards Points: 1,070
Adequate ventilation is the key, no matter what thickness of drywall you use. If it it absorbs enough moisture it will sag. You might want to replace/upgrade the fan while the ceiling is open if it's an older model...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-25-2009, 09:27 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
On a side note: 5/8" moisture board is readily available in my area.
Sir MixAlot is offline   Reply With Quote
Old 04-27-2009, 07:35 PM   #5
Drywall contractor
Ignore that. Someone had another question posted but must have come back and deleted it.
Old 04-28-2009, 10:34 PM   #6
24"---Why do you ask?
Old 05-02-2009, 12:30 PM   #7
Fast1---I don't get the point. Please explain
Old 05-02-2009, 12:45 PM   #8
good luck to you bathroom ,do you use any chinese products?
if you have used , please kindly let me know.thanks.
silence xu is offline   Reply With Quote
Old 05-02-2009, 03:35 PM   #9
I only use Chinese products. If it says made in the USA I buy it some where else
Old 05-02-2009, 03:54 PM   #10
wish our chinese products can give you luckly.best regards for you.
by the way,could you please give me some informations about anybody who sales stones(chinese stones) in american . email is ok.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
New bathroom fan loud in ceiling mbs13 HVAC 14 03-18-2008 05:51 AM
ceiling fan installation PLEASE someone help finleygoddess7 Electrical 35 03-08-2008 10:41 PM
