-   -   Bathroom Ceiling Installation (http://www.diychatroom.com/f19/bathroom-ceiling-installation-43222/)
MikeyP 04-25-2009 10:51 AM
Before I get started I wanted to make sure I'm installing the sheetrock on my bathroom ceiling correctly. The ceiling is 24" OC and I'm going to use 5/8" sheetrock. From earlier posting I've decided not to use greenboard on the ceiling because it's less rigid and be more likely to sag. There is an exhaust fan in the bathroom
I also understand that I don't have to run strips perpendicular to the rafters because I'm using 5/8 sheetrock.
Can you confirm what I'm doing before I get started?
Bob Mariani 04-25-2009 04:01 PM
This will work fine. I would suggest using Zinsser's Perma White paint to finish this ceiling. You can tint it to any color. But as a self priming solution you will get active fungicide in all three coats allowing a much longer protection period to prevent mold.
bjbatlanta 04-25-2009 06:03 PM
Adequate ventilation is the key, no matter what thickness of drywall you use. If it it absorbs enough moisture it will sag. You might want to replace/upgrade the fan while the ceiling is open if it's an older model...
Sir MixAlot 04-25-2009 09:27 PM
On a side note: 5/8" moisture board is readily available in my area.:thumbsup:
bjbatlanta 04-27-2009 07:35 PM
Ignore that. Someone had another question posted but must have come back and deleted it.
MikeyP 04-28-2009 10:34 PM
24"---Why do you ask?
MikeyP 05-02-2009 12:30 PM
Fast1---I don't get the point. Please explain
silence xu 05-02-2009 12:45 PM
good luck to you bathroom ,do you use any chinese products?
if you have used , please kindly let me know.thanks.
MikeyP 05-02-2009 03:35 PM
I only use Chinese products. If it says made in the USA I buy it some where else
silence xu 05-02-2009 03:54 PM
wish our chinese products can give you luckly.best regards for you.
by the way,could you please give me some informations about anybody who sales stones(chinese stones) in american . email is ok.
