Old 01-17-2008, 03:46 PM   #1
bathroom basement subfloor on concrete slab
What is the best basement subfloor to install over a concrete slab, below grade, northern climate, concrete is level, clean and prepped, for a small 10' x 7' bathroom? I was thinking vapor barrier (polyethylene) with 3/4" plywood over the top. Planning on vinyl flooring for finish, any suggestions?
Gus72 is offline   Reply With Quote
Old 01-17-2008, 03:54 PM   #2
use those orange membrane like plastic but with cloths. thing... forget its name somthing like ditel....etc.....they are not flat ...
it is quite expensive but it is very good.....
you can use those other tiling backer blocks but plywood definitely an older technology and shouldn't be used....
KUIPORNG is offline   Reply With Quote
Old 01-17-2008, 05:22 PM   #3
Question
how thick is this stuff ?
why can't tiles go directly on the concrete ?
should this be done across the whole basement or just in the bathroom ?
if i plan to have carpet in most of my concrete slab basement apartment, does anything need to be in between ?
thx,
- a -
Old 01-17-2008, 06:47 PM   #4
Where can I find the orange backer cloth's? Home Depot? What would you recommend instead of a plywood subfloor? I could use sleepers,but I want to keep the height down, I don't want a big lip into the bathroom. Maybe 1" x 2" s?
Old 01-18-2008, 12:08 PM   #5
the orange stuff is really thin... thickness is neglectable.... that stuff is either called ditel or dicore... I kind of forget....
Old 01-18-2008, 12:35 PM   #6
Tile pro
All Tiles's Avatar
vapor barrier (polyethylene) with 3/4" plywood over the top is what i would use. Remember that basements retain a lot of moisture, therefore, having any kind of padding/sub flooring will make your floors a lot less cold in the winter.
All Tiles is offline   Reply With Quote
Old 01-18-2008, 12:38 PM   #7
Are you speaking about the ceramic tile product, Ditra? He said he's putting down vinyl. It would really help if you read the post before making incorrect comments especially when the poster didn't realize you were speaking about the wrong product for his stated application.
You can put the vinyl right on the concrete if it's as flat as you say it is.
Ron
Old 01-18-2008, 02:52 PM   #8
you are right... didn't see it is vinyl.... I thought he will use ceremic tiles.........
Old 01-19-2008, 03:35 PM   #9
To minimize the height difference you can put down foamboard down between some sleepers. Decide how high you can live with and use the appropriate thickness foam. As stated before, use a vapor barrier over the concrete.
You could eliminate the floor buildup all together by using electric radiant floor heat and ceramic tile.
Ron
Old 01-19-2008, 06:57 PM   #10
Thanks for the reply Ron! I think I will use your idea of foamboard between sleepers. I am trying to keep the cost to a minimum so the electric radiant heat under ceramic tile is a little out of my budget. Thanks again and I'm sure I'll have more questions in the future!
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 06:37 AM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
