Bathroom: Bare Green Drywall & Moisture - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 10:26 PM   #1
I had re-dry-walled my bathroom a few weeks ago. A friend had passed away and never finished the bathroom. I'm going to try to get it done this weekend. All I did was hang the green drywall. Did not tape or paint it. It's been two to three weeks. We have been using the bathroom and taking showers since then and am a bit concerned about the moisture to an unfinished wall.
Should I be concerned?
As a precaution, should spray a mildew solution on the drywall before I start taping and throwing up joint compound? Before I tape, do I caulk
the joints?
Three of the walls are plank boards, no wall cavity. The other wall is a standard 2x4 wall that is unfinished on the other side. Ceiling I'm more concerned with, as part of the ceiling does not have attic space. That section is right above the shower. Behind the drywall wall , is rigid foam with an air channel between the roof sheathing and foam.
drex is offline   Reply With Quote
Old 01-12-2011, 10:50 PM   #2
Registered User
Termite's Avatar
Green drywall is appropriate for use in a bathroom, but NEVER in an actual wet area like a shower or tub surround. Cement board tile backer is the product you need to use under the tile. If you're using a Kerdi membrane under the tile you can apply it over drywall.
Green drywall is not designed to get actually wet, so if it is in your shower and you've exposed it to direct contact with water you can rest assured that it has absorbed a good amount of it. If that's the case I'd advise you to remove it from the wet area and start over with the proper product. If there's a band of drywall above the tile then the green drywall is appropriate, provided it is in an area that isn't going to get wet.
The modern I-codes actually prohibit gypsum wallboard in wet areas, for good reason.
Old 01-12-2011, 10:56 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
thekctermite is correct, just one caveat though, according to the IBC greenboard should not be used on ceilings as it is possible that if a leak happens above the greenboard it could possibly hold enough water to cause a sudden catastrophic collapse of the ceiling instead of a gradual leak through.
Andy.
AndyGump is offline   Reply With Quote
Old 01-13-2011, 10:42 AM   #4
Sorry I should of have been more clear. The area surrounding the tub I had already tiled in the past and used cement board. I had used green for the rest of the bathroom. So the area above the tile and the surrounding walls is greenboard.
So my concern was with moisture for the surrounding walls and ceiling.
Is there a concern with the moisture in the room for the bare green board?
As far as the ceiling, what should have I used?
It's a tub and not an enclosed shower. I thought regular drywall on the ceiling would be a bad idea due to the moisture rising above the tub/shower.
Old 01-13-2011, 04:30 PM   #5
MR board will sag on a ceiling. Do not caulk the joints! Just tape and sand then use drywall primer and a top coat of something like Permawhite.
mrgins is offline   Reply With Quote
Old 01-13-2011, 06:48 PM   #6
Chicago, IL
Michael Thomas's Avatar
Andy.
Andy,
Do you have a cite for the code commentary which discusses the "collapse" issue with Water Resistant Drywall?
Not doubting that it could be the case, it's just a new issue to me (I know that WRD requires max 12" support spacing when installed on ceilings, but I've always been told this was to reduce "pillowing"), and I'd like to know more about it.
MDT
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 07-08-2012, 08:02 AM   #7
www.No-Curb.com
JohnFRWhipple's Avatar
Originally Posted by Termite View Post
Green drywall is appropriate for use in a bathroom, but NEVER in an actual wet area like a shower or tub surround. Cement board tile backer is the product you need to use under the tile. If you're using a Kerdi membrane under the tile you can apply it over drywall....
In Vancouver drywall is not approved in any shower - covered with Kerdi or not.
In a steam shower drywall is not listed as an approved backer board by either the TCNA or the TTMAC
Drywall anywhere in a wet zone is a foolish idea.
JW
"When it's Perfect. It's good Enough." - John Whipple
JohnFRWhipple is offline   Reply With Quote
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 12:04 PM
I have too much moisture in my bathroom mrobey Drywall & Plaster 0 09-04-2010 11:07 AM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
Bathroom Drywall Questions Riddler Building & Construction 6 06-27-2006 10:36 AM
Painting bathroom with lots of moisture? DK75 Painting 2 02-08-2006 12:08 PM
