Old 12-23-2012, 12:57 PM   #1
bath exhaust
I have determined the CFM exhaust I need for my bath to be 80; however with almost all baths, privacy with a closed door reduces the amount of airflow into the bath. My 24" door has a 1" opening at the bottom for airflow. I don't know how much air CFM this allows into the bath nor what the consequences are for my bath motor if this is insufficient.
Should I be concerned with this restricted air flow into the bath?
Captflx is offline   Reply With Quote
Old 12-23-2012, 01:52 PM   #2
Master General ReEngineer
Bondo's Avatar
bath exhaust
Ayuh,... That's 24 sq. inches....
How much air ya gonna push through a 4" flex-vent tube,..??
Old 12-23-2012, 02:07 PM   #3
AHH, SPANS!!!
bath exhaust
spaces under doors are 5/8" up to over an inch average. as long as it is at least 5/8" off the floor the a/c-heat unit and bath fan will work just fine.
hand drive is offline   Reply With Quote
Old 12-24-2012, 06:01 PM   #4
bath exhaust
yea you will be ok. i will be more concerened with the length of the duct run
federer is offline   Reply With Quote
Old 12-25-2012, 11:08 PM   #5
bath exhaust
I think you must add a small decorated window (A very small one) to your door so that air can pass through it properly but make sure you don"t see on the other side from any position and like wise.
pool shop
jasson is offline   Reply With Quote
Old 12-26-2012, 12:56 AM   #6
JOATMON
ddawg16's Avatar
bath exhaust
Do what? I don't believe that is any code I have seen.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 12-26-2012, 08:31 AM   #7
bath exhaust
Never heard of it either. Nor have I ever seen a bathroom door with a window in it.
md2lgyk is online now   Reply With Quote
Old 12-26-2012, 09:28 AM   #8
bath exhaust
how did you determint the required cfm?
gwilkrrs is offline   Reply With Quote
Old 12-26-2012, 11:30 AM   #9
bath exhaust
By the size of the room.
Old 12-26-2012, 11:58 AM   #10
JOATMON
ddawg16's Avatar
bath exhaust
Suggested CFM for the bathroom is based on cycling all the air in the bathroom 8 times per hour. The bath fan calculator is standard guide to help you find the minimum fan rating for your specific bathroom. The higher the bath fan rating the more air can be vented out of the bathroom, which means less moisture and mold build-up.
One of many web sites for calculating the cfm...
http://www.ventingdirect.com/bath-ex...culator/c16459
My
and
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
gwilkrrs (12-27-2012), RobertoAguiar (12-26-2012), Windows on Wash (12-26-2012)
Old 12-26-2012, 12:19 PM   #11
Send a message via AIM to RobertoAguiar
bath exhaust
Wow thank you very nice link, very helpful information.
RobertoAguiar is offline   Reply With Quote
Old 12-26-2012, 04:07 PM   #12
bath exhaust
Thanks to all for the info.
Old 12-26-2012, 06:52 PM   #13
Exterior Construction
Windows on Wash's Avatar
bath exhaust
Bookmarking that one.
Nice link.
Old 12-26-2012, 11:51 PM   #14
Moderator
bath exhaust
I'll stick with mine; flex duct, elbows, and roof/wall cap deductions; http://www.efi.org/factoids/bathroom_sizing.html
Lol.
Gary
PS. Termination hoods/fittings also create back pressure; from my dryer links; http://www.youtube.com/watch?v=cFOHGVhmyQA
Clothes taking longer to dry?
Bath Exhaust Fan Timer Switch--2 Switches in Series hammerlane Electrical 5 01-07-2012 07:09 PM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 06:05 PM
Bath Exhaust vs Joinsts On Iowa! Remodeling 3 01-08-2010 04:52 PM
fitting a replacement bath exhaust in a bigger hole mayhem69 General Discussion 3 01-26-2009 06:04 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
