Basment Reno Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 05:16 PM   #1
Im starting my basment reno and have some questions
I know most will suggest spray foam or XPS to insulate but im not, im going to use Roxul.
Question #1
Should i use Typar or Tar paper against the concrete i find so many mixed reviews on this subject
Typar's descripton is an AIR BARRIER, I dont want to create a double air barrier as im going to do a vapour barrier on the warm side will typar create a double vapour barrier?? which is a better product to use?
Question # 2
Should i build my floor first or my stud walls?
I have talked to 2 neighbors one who did studs than floor one who did floor than studs.
I can kinda see a positive by doing the floor first.
If i hang typar or tar paper from the sill plate and let it drape onto the concrete floor a bit, then build my floor the studs will be above that thus if any moisture issues arise the bottom plate shouldnt come in contact with the moisture/water and i would not need to use sill gasket or P/T studs
Any help is appreciated on this
Thanks!
jarn_76 is offline   Reply With Quote
Old 08-04-2010, 05:12 PM   #2
No one has any input
Finishing basment...light questions and more. Abs777 Electrical 10 02-19-2010 10:22 AM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
washroom reno questions MARVIN M Flooring 5 07-09-2009 03:48 PM
hardie plank reno questions hansolo2 Building & Construction 1 10-02-2008 03:10 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
