Basment Block Mortar Joints Crumbling, 40's Era - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 08:10 PM   #1
Rewards Points: 562
Basment block mortar joints crumbling, 40's era
I just got in from 'trying' to retuck point a few bad places on my foundation block joints.
First off,with a screwdriver and scraping a bit of loose stuff out of cracks,it ALL comes out,mostly. its just crumbly like sand with elmers glue attached.
I had mixed up a paint pan with enough to fix half dozen spots"I thought". I stuffed and stuffed the 'first' seam and ALL of the mortar just falls inside and down inside bottom blocks.
Do you put a block or filler inside 'first'?? other wise it will NEVER fill up. This block is on a house estimated to be built back in the forties,,with the extra jagged block,defined heavy, on outside edge to look like heawed concrete stone,,,about 2-3" deep texture all over.
Was wondering IF instead of trying to tuckpoint this thing,,,which would make new mortar places stick out like a sore thumb bandaid,,,whether a WHOLE foundation recovering with surewall would be better option and NOT scrapping loose mortar out too badly,to use as a backer to keep it from falling away forever???
It would take a whale of a amount of 'surewall' (to fill in those voids to be semi-smooth),,but a better stabilized end product that would look better,more like a white painted look without painting it over and over,of which blocks historicaly dont hold paint well anyway!!
Number ONE goal is a stable secure foundation,which is NOW crumbling,,No. 2 goal is to keep cold weather out(coming sooner than we want) and also tons of MEECES!!!
So long question short,tuck or surewall?? thank you for your reading and suggestions-d-
4just1don is offline   Reply With Quote
Old 09-03-2008, 11:09 AM   #2
Rewards Points: 562
NO opinions??ideas?? FIRST time I EVER saw this board speechless!!-d-
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
