-   -   Basic help with window and door rough framing (http://www.diychatroom.com/f19/basic-help-window-door-rough-framing-154252/)
danf26 08-19-2012 11:18 PM
Hello,
This topic must have been discussed already on here, but I need some help understanding window and door framing. I have bought a bunch of used and salvaged windows and a door for a small cabin Im building, and I have no idea how to figure out their rough openings. Some of the windows are vinyl clad on the exterior, and still have some of their nailing flanges (remember these are salvaged so they have already been installed once and removed once). But some windows are "picture windows" - that is they dont open and also dont seem to have any nailing flanges. How will they be secured into the framing? How will I figure out their ROs?
And the door I have has no framing around it. Its just one piece - a door. How will this interact with the rough framing and how should I determine the RO?
Any good general sources that can answer these basic questions? Books? Videos online? People to talk to?
Thanks!
joecaption 08-20-2012 12:05 AM
Good luck with trying to do it that way.
Each window will have to be trimmed and installed differantly.
Going to end up with some funky looking trim around the windows to make it work.
As far was the R/O you should be able to get away with 1/2" bigger then the window frames in both directions.
What do you plan on using for siding? Differant siding is done differant ways when installing windows.
Just a door slab is usless without a frame. If the plan is to use it for an outside door, it would be far better to just go buy a new prehung door so it will seal.
(windows with no nailing fin are called flat jams.)
TheCamper 08-20-2012 09:33 PM
A photo of the windows would help us guide you. Basic guidance is to hang the door in a frame first and then install it. If the "picture window" is just a sash then you need to build a frame for that also, if it has a frame you can get wide "L" brackets (http://www.fullie.co.nz/index.php?ma...roducts_id=251) that screw into the window frame and nails into the cabin's framing.
hand drive 08-20-2012 10:51 PM
Originally Posted by danf26 (Post 992491)
Hello,
Thanks!
consider a door jamb kit along with a door threshold, to build the jambs for the door slab you have and don't forget door hinges too. you can build a door jamb assembly out of 1x6 as well.
What type of siding will be on the cabin? Thanks
