Basic Foundation Replacement Cost - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 03:06 AM   #1
Question
I am a student at Cal Poly SLO and i'm trying to estimate the cost of building a 'simulation warehouse' next to another existing building. It's basically just a small building with big doors and storage racks on the inside. It will also most likely have power/internet so they can connect to the campus servers inside the building but that doesn't really have anything to do with the foundation, or does it?
The area is 25ft x 22ft in San Luis Obispo, California. There will be no plumbing. Keep in mind my professors main goal is to make it as cheap as possible (any suggestions on building wall material would be helpful too).
My main question is concerning the foundation. Where my prof wants to build it there is already a concrete foundation (maybe 6-8 inches thick) but it is in pretty bad shape since it is exposed. It has a couple pretty big cracks in it and looks a bit uneven.
So the question: Do i need to replace this concrete and put in a real foundation?
And, if anyone could give me a rough estimate that would be great.
Cspear is offline   Reply With Quote
Old 05-11-2011, 07:23 AM   #2
Rewards Points: 4,534
Cal Poly - Where Learn by Doing Transforms Lives
California Polytechnic State University, San Luis Obispo
guess calpoly's not high on the language arts to start, you might suggest your webmaster ask for the proper english
why cheap ? foundation's are usually measured in width - yours sounds like a slab - doesn't cal poly have an engineering dept ?
Old 05-11-2011, 07:38 AM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Buiding with big doors(wide, high or both?) and racks indicates there may be forklifts or possible concentrated loads on a cracked 6" to 8" slab. - Not a good situation/combination and it would be prudent to put in a new, proper slab rather than take a chance on trying to replace it after the new building is built on top of it.
If you try to use the existing slab, it will have to be certified as acceptable for the loads by an engineers before anyone can get a permit to build the the new "garage" on top of it..
You have to address the low inial cost with the long term replacement/repair costs.
It is sure a simplistic, unrealistic problem unless the prof wants to use it as a garage for his car. Just a text book problem without regard to the real world.
Dick
concretemasonry is offline   Reply With Quote
Old 05-11-2011, 12:56 PM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
The path to knowledge is more rewarding when you're the one holding the flashlight.
Green Building Square Foot Costbook
by Sweets, 2011
It's in the Kennedy Library on the Cal Poly SLO campus, North Perimeter Drive, 1st floor, reference section, TH880.G744 Ref. It's checked in and available.
That took me 20 seconds to find using the Library's web site. The rest is up to you. For such a small structure, I'd add 20% to the square foot costs.
Aggie67 is offline   Reply With Quote
Old 05-11-2011, 02:36 PM   #5
General Contractor
LakeTahoeDan's Avatar
Sounds like it is just a slab and 6-8" would not be structural for any building on it. Are there deeper footers on the perimeter or stem walls?
post some pictures
LakeTahoeDan is offline   Reply With Quote
Tags
concrete , cost , estimation , foundation , student
rough estimate of foundation on slope billv Building & Construction 9 08-22-2015 10:23 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
frost protected shallow foundation retrofit for 100+ year old limestone foundation degnem Building & Construction 7 06-24-2010 07:33 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 07:28 PM
