Basic Deck Build - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 09:07 PM   #1
Question
Basic Deck Build
I'm planning to build a patio deck on the back of mobile home. The area is not large and it should be pretty basic to build. I'm also planning to install a sliding door that leads out to it where a window currently is.
Can anybody point me in the directions of some basic how to books with the latest construction techniques in order to help me get started on the planning of this project?
Also, for a basic deck build is there any design software you would recommend?
Lastly, where can I go to compare different building material options? I live near the sea and I'm worried about rot.
Thanks.
tr7111 is offline   Reply With Quote
Old 01-17-2012, 09:17 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I guess Google "Deck Framing".
Whatever treated lumber they're using by the sea.
titanoman is offline   Reply With Quote
Old 01-17-2012, 09:19 PM   #3
will it be hard for someone who has no experience doing carpentry but is pretty good with directions?
Can I get all the lumber precut with the proper plans?
Old 01-17-2012, 09:35 PM   #4
Disabled wood vet
titanoman's Avatar
Yes it's hard.
No, I don't think anybody will pre-cut lumber even if you gave them a plan.
I think maybe you should find a contractor for this.
The Following User Says Thank You to titanoman For This Useful Post:
woodworkbykirk (01-17-2012)
Old 01-17-2012, 09:47 PM   #5
Rewards Points: 13,274
I agree.
In the time it would take someone to build this for you, you would not have had time to figure how to build it.
Your going to need a permit for this, I would strongly suggest not using a sliding glass door. Air leaks, roller maintaince ect. Go with a french door or a reguler door.
The roof for this is going to have to be built so it goes as high as possible on the roof you have now in order to get the needed slope and still have a high enough outside wall for a door to fit in the wall.
What do you think your budget is going to be?
Old 01-17-2012, 10:22 PM   #6
Well when I first looked into having a contractor do it I was given ballpark estimates of 5k which is not worth it to me. I'd like to spend as little as possible. Its just a mobile home but it has a great ocean view I'd like to take advantage of.
I have no problem with a regular door since it would be cheaper that way. I have friends who are knowledgeable should could help.
What's the cheapest way to do this?
Old 01-17-2012, 10:27 PM   #7
Now you have lost my interest, look over some of the thousands of post on here where people insisted on doing it cheap and fast and there back wanting to know how to fix it.
Build it cheap, use under sized materails, cheap shingles and it's going to leak and fail.
Just the materails will be about $2000.00 or more if you install a roof, door and windows.
Old 01-17-2012, 10:28 PM   #8
Disabled wood vet
titanoman's Avatar
What do you expect me to do?
Walk you through the whole process starting from scratch when I'm not even there to see the situation?
Old 01-17-2012, 10:30 PM   #9
Not to mention the fact that its a mobile home which is more of a challenge than a stick built house
mrgins is offline   Reply With Quote
Old 01-17-2012, 10:32 PM   #10
Right I expected it would cost that much for the materials alone. I was hoping to save money by doing it myself though. Is it really futile to try to get good plans drawn up and do it myself? Were only talking like 10 square feet with no stairs
Old 01-17-2012, 10:35 PM   #11
I went back and reread your post add about $500.00 for a slab.
The concrete company is going to hit you with a small delivery charge.
And no it can not be done with just bags of concrete and have it come out anywhere near right.
Plus it would take 111 40 Lb bags.
http://www.concretenetwork.com/concr...calculator.htm
Old 01-17-2012, 10:42 PM   #12
Disabled wood vet
titanoman's Avatar
2 feet by 5 feet? That's not even big enough for the door to open.
That one quote was $500 a square foot. A little high.
I think you mean 10x10 feet, which is 100 square feet.
Old 01-18-2012, 02:40 AM   #13
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Well I have to disagree with some posters about the difficulty level of building a small deck.
As long as you have a good set of plans that will show you most aspects of building the thing I don't see why you or anyone else could not do it.
You may not even need a permit or railing depending on your location.
But even if you do not need permitting you should build it so it is safe, PM me if you wish.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
12penny (01-18-2012)
Old 01-18-2012, 07:44 PM   #14
robertcdf's Avatar
$5K? sounds like a deal to me, I don't have a roof/deck combo that costs anything less than $20K and most are $30k - $40k.
robertcdf is offline   Reply With Quote
Old 01-18-2012, 07:51 PM   #15
Disabled wood vet
titanoman's Avatar
I don't think anybody has said anything about a roof over this one.
5 grand is $50/ft- way too much for no stairs or railing.
Tags
deck
DougFir Deck - Stain Before or After build? mntnvew Carpentry 15 06-09-2015 12:55 AM
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 10:40 PM
