#1 |
Basement XPS and Batt insulation?
Was just wondering about this, we want to have 2x4 walls jus because of the pipes we want to cover up and such in the unfinished basement.. can we put 1" of XPS foam on the wall first, glue it up, seal it's cracks up with tyvek tape, then build the walls frame infront of that and then fill the walls up with batt insulation? our area requires R-10 minimum in conditioned spaces the 1 inch foam would give us R-6.5 then the batt insulation would add another R-13... any problems with this? everything would be drywalled over in the end
it would look like this basically http://i.ehow.com/images/GlobalPhoto...-main_Full.jpg also is there any big difference between Johns Manville batt insulation and Owens Corning? OC costs almost twice as much where I am at.... Last edited by BlueBSH; 01-14-2010 at 04:27 PM. |
#2 |
Here to Learn
Johns Manville is formaldehyde free. You can't go wrong with them. R value is R value.
#3 |
Moderator
Good plan! But use unfaced foam board: http://www.buildingscience.com/docum...ent-insulation
Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 | |
Basement XPS and Batt insulation?Quote:
#5 |
Moderator
Yes, as per Building Science, the more permeable (thinner), the better.
The best foams to use have a perm rating of greater than 1 perm for the thickness used. This means limiting extruded polystyrene insulation to less than 1-inch thickness for walls (more than 1 inch thick and they do not breathe sufficiently) and making sure that the rigid insulation is not faced with polypropylene skins or foil facings. From: http://www.buildingscience.com/docum...gs?full_view=1 Be safe, Gary
| Display Modes | |
