Old 10-31-2009, 03:49 PM   #1
Default Basement wood shop - keep that dust in!
Hello all!
I am about to close on a house and eager to set up my wood shop. I have some modest tools I use in a garage at the moment, but I plan on using them in my new basement.
My problem is, I want to keep the dust in. Its an unfinished basement, so there are no walls. Best I can think of is a plastic curtain hung from the ceiling with weights on the bottom. I would have the curtain drag on the ground for "optimum" dust containment. I'm still going between having the curtain move to the side (like shower) or if I would have it simply roll up or fall down.
Anyone have another idea or any suggestions for materials?
Thanks in advance!
Amall23 is offline   Reply With Quote
Old 10-31-2009, 05:18 PM   #2
I have one suggestion for you that solve quite a bit of dust problems. Npo doubt you will end up using a palme sander at some time and all palm sanders have a series ofducts under the rubber pad supoposedly to direct the dust into that stupid little bag. What I did was to remove the pad and use it as a template marking the holes. After wards I punched out the holes on my 1/4 sheet papers. Instead of the bag I modified one of those long narrow vacuum tools to fit where the bag fitted and the other end to fit a one inch hose. Put the paper on the sander base so the holes in the paper line up with the holes in the rubber pad. Turn on the shop vac or whatever and all the dust with get sucked up by the shop vac. You will be amazed that there is no dust in the air. It may be a start to help keep your dust level down.
Wicked
wicked is offline   Reply With Quote
Old 10-31-2009, 07:06 PM   #3
A curtain will hold in some of the dust but you are going to find it hard to breath before too long in there. What you are going to want to do is get a vaccuum system with hoses that attach to your equipment and a air puritfyer system. These will cost a little money but they are worth the money you spend. I bought mine from Menards. My system are made by Jet and it works really well. I used to have my shop in my basement ban when I use them down there, there was a noticable difference. The vaccuum system will get most of the saw dust and chunks of wood, and the air purifier had filters that sucks the amdient air in the room through it and collects all the dust in the air. If you don't have the money now I suggest you save for it if you plan to keep your shop in the basement.
RobQuillin is offline   Reply With Quote
Old 10-31-2009, 07:20 PM   #4
Making custom shopvac attachments.... that's a great idea!!! Thanks wicked, I'll definitely have to try that out.
I hadn't thought about ventilation.... my dads wood shop is HUGE and is always fine. The area I'm thinking of fencing in has a window there....a broken window. I had planned on adding a ventilation system with it so I could paint. Adding something for air filtration would be pretty easy too.
Thanks all.
Old 11-02-2009, 04:57 PM   #5
Default Dust control
You might want to invest in a ceiling hung air filter system. They usually come with a foam pre filter but I tossed that out quick and rtepalced it with furnace filtersI bought mine from Lee Valley but they no longer sell them but they must be available elsewhere. If you live in Canada Busy Bee Tools have several different types.
Wicked
Old 11-02-2009, 10:55 PM   #6
Wicked
X2 on the ceiling hung air filter - I have one, works well.
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip, I will be talking about more parts of our sander. In the center area of our tool, we have our motor housing. These slots are vent holes so that air can get to that motor and keep it cool... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we would be attaching the dust bag. On the back of our tool we have our blower exhaust and we have our dust bag. Now the dust bag is going to provide a type of dust collection system for the... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clilp I will be talking about the parts of a finishing sander. First off we have our on/off switch which is located in the front of the sander. This is what will supply power or shut the power... Read More »
I'm Rob McManhon with Expert Village. There is different types of sand papers as well. There is the belt for the belt sander. For the random orbit or the disk sander there is this type which is a hook and loop it is basically Velcro and its pad has the... Read More »
Hi! I’m Rob McMahon for Expert Village and I’m going to talk about the safety of a table saw. Probably the first thing is safety glasses, which come in all different styles these days. There’s clear and then there’s colored ones... Read More »
basement floor drain problem radioiowa88 Plumbing 5 10-23-2008 12:52 AM
Drive out basement footers? Sethsmum Building & Construction 0 05-01-2008 06:08 PM
Between coats of polyurethane on wood floors, how do you get up the dust? proofer Painting 1 04-07-2008 09:27 PM
To AC Basement or Not? jacko10 HVAC 0 09-20-2007 05:44 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 11:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
