Old 10-11-2008, 06:10 PM   #1
Default Basement windows above floor joists
Hi everyone,
I'm framing my basement and need some advice. Against one exterior wall, the builder put in two small windows. The glass measures 7" x 24", so they don't let in very much light.
About 1 foot in from the windows, an I-beam runs the width of the room, across both windows, further limiting the view of the outside.
And for the final straw, I took a closer look now that I'm framing that part of the basement. And I found that the windows were put in 4" above the floor joists. Even if I drywalled the ceiling without using furring channels, I'm going to be hitting the windows.
As I see it, I have three options:
1. Build a U-shaped soffit around the I-beam and leave the ceiling open on the side nearest the wall.
2. Carry the soffit to the wall and cover up the windows altogether.
3. Lower the windows so that the top is below the floor joits (or brick them in to remove them altogether.
Has anyone ever seen this and if so, what would you advise? I'm leaning toward just carrying the soffit to the wall, covering up with windows and being done with it. But that seems like a halfway measure, plus I don't know what code would say about that. I have no plans to put a bedroom in the basement. I really don't want to put in a well. There's a deck on the outside which I'd have to dismantle to do it and that would land me in the doghouse!
Thanks.
basement-windows-above-floor-joists-img_0019.jpg   basement-windows-above-floor-joists-img_0020.jpg   basement-windows-above-floor-joists-img_0021.jpg   basement-windows-above-floor-joists-img_0022.jpg
billthecat is offline   Reply With Quote
Old 10-11-2008, 08:45 PM   #2
Keep in simple. I sounds like moving them would be a real involved project.
Here is a way to get light spread around.
When you build a soffit in the window area use angled walls and paint them a bright white. This will reflect the light around and keep from blocking out anymore light. You could even go as far as installing mirrors in there to really reflect the light although I think some bright white paint will do just fine.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-12-2008, 12:57 AM   #3
Yep,just frame up to the top of them and call it a 'light' chute for lack of better term. At what height are these windows from ground level on the outside?? Can you move over a bit,,,different spot on wall and put in a deeper longer window??? NO amount of purchased light is as GOOD as sunlight,,,,without ANY windows it gets WAY too dark!!! If necessary those metal window wells work pretty good,,,with a plastic umbrella over the top!!
4just1don is offline   Reply With Quote
Old 10-18-2008, 11:51 AM   #4
I do have some room if it came to that. The windows are about 1-1/2 feet above ground level. Of course, that would lower them below the deck right outside so that would do away with the natural light benefit.
So it looks like I'm going to build a soffit around the windows. I *really* don't want to take my deck apart, dig down and put in window wells!
Old 10-18-2008, 10:56 PM   #5
Are you finishing your basement? Do you have an existing method of egress?
You may need to put in a egress window if you finish the basement.
Where I live, they require us to have a method of egress for new construction wether the basement it finished or not.
KHouse75 is offline   Reply With Quote
Old 10-18-2008, 11:07 PM   #6
I haven't read the code (I'm not even sure how to get my hands on a copy) but have read that in most places in Canada, you need an egress window in every bedroom. I'm not putting a bedroom in so hopefully that's not a requirement. I really am not prepared to take on the expense and hassle of ripping apart / rebuilding my deck, digging down to the weeping tile, knocking out a bigger hole in my exterior wall, installing a window well, etc, etc, etc.
That said, it would be a good idea for me to find out what that code says.
Old 10-19-2008, 12:46 AM   #7
Building codes guy, Mod
thekctermite's Avatar
Here in the states you need an egress window in every bedroom, and one (or an exterior door) on every level of the home that doesn't have a bedroom.
Here, if you finish your basement for just living or recreational space, you need to install an egress window. Not fun.
thekctermite is offline   Reply With Quote
Old 10-20-2008, 10:07 AM   #8
Yep, Before you spend one dime.
Tags
basement, floor joist, framing, window
More On This Topic
So we're back at the Vine Ridge house and it's really exciting because, now we've got the walls off and we can see what's behind. We had some exciting things evolve. As I was leaving the property, I noticed that there was a second story window and I... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Basement Egress Windows rescueswimmer General Discussion 3 07-18-2008 09:49 AM
basement windows Richmarti12 Building & Construction 0 03-15-2008 10:45 PM
Insulating basement windows Keyo77 General Discussion 3 01-06-2008 08:33 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 08:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
