Basement Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2009, 03:33 PM   #1
basement windows
I have 3 windows in my basement that has caved in do to dirt so I'm having some one come and put in window wells but the glass in the windows are broke so my question is can we replace then with cement and if so how do we go about it thank you neva
nevajane57 is offline   Reply With Quote
Old 07-10-2009, 04:24 PM   #2
I have a similar situation, i have some busted out windows and the things are expensive. I wondered if i could just fill them in with glass block or something instead.
I imagine that most likely basement windows are there by code, otherwise you would see a lot more houses that have no basement windows at all. I know that for new homes, you have to have an egress window for the basement if it is to be finished.
But yeah, i was wondering how many you have to have, or if you can block some in, and for ones that I would have to replace, how you replace a basement window on the cheap? Those things are expensive!
aeridyne is offline   Reply With Quote
Old 07-10-2009, 06:12 PM   #3
You are not required to have windows in a basement
You are required to have a means of egress if you convert a room in the basement to a bedroom
There are very specific codes & size requirements for a basement bedroom window
Most of the "normal" basement windows will not meet that code requirement
Old 07-10-2009, 10:08 PM   #4
Registered User
Rewards Points: 5,516
You are required per code to have a sliding glass door or a window in the basement: Light-- In habitable rooms, natural light min. 8% floor area {10% & min. 10 sq. ft.} IRC 303.1 UBC 1203.2
As Dave said all bedrooms need a window for egress and light. The bedroom egress sized window can serve the basement, but not the other way around. You still need a fixed window for light requirements for the basement. Be safe, G
Old 07-10-2009, 10:20 PM   #5
Sorry, did not include - if the basement is not finished - then a window is not needed
Sec. 1203.2 Light.
Guest rooms and habitable rooms within a dwelling unit or congregate residence shall be
provided with natural light by means of exterior glazed openings with an area not less than one tenth of
the floor area of such rooms with a minimum of 10 square feet.
EXCEPTIONS:
1) Rooms located in basements may have exterior glazed openings with an area not less than one
twentieth of the floor area of such rooms with a minimum of five square feet.
Old 07-11-2009, 12:24 PM   #6
sweet! I'm just going to glass block or shut em up entirely for the broken out ones, they are way too much to replace, 300 bucks for a basement window is highway robbery!
Old 07-11-2009, 02:00 PM   #7
As long as you have a bulkhead or door leading outside from the basement
My basement windows were $50-60 each - what are you buying ???
Myself I like the windows for light
Old 07-11-2009, 02:25 PM   #8
no idea really, lol, obviously. maybe i will just replace the windows after all.
Choices in Replacing Basement Windows 2031pratt Remodeling 3 06-06-2009 07:00 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Basement windows in masonry walls dave11 Building & Construction 1 03-20-2009 08:28 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 08:07 AM
