-   -   Basement Windows (http://www.diychatroom.com/f19/basement-windows-171759/)
brockmiera 02-12-2013 10:57 AM
Basement Windows
I can see some light coming through around my basement windows. What should I use to seal them up? The previous owner thought a GALLON of caulk would do the trick but unfortunately it didn't. Foam? More Caulk?
md2lgyk 02-12-2013 11:15 AM
Is this a finished basement? If not, you could probably just spray foam the gaps where you can see light. Remove as much caulk as you can so the gaps are more fully filled with foam. But I would question why that much caulk didn't fix the problem.
brockmiera 02-12-2013 11:26 AM
I'm in the process of finishing the basement now. I'm pulling out the caulk because the boss said it doesn't look good. She's right. I'll try and post a picture later. It looks like they tried to use foam but the foam had degraded over time.
dengle 02-12-2013 06:43 PM
A quick anecdotal story. I bought my house almost 2 years ago. It was about 10 years old at the time. My daughter was down in the basement watching TV and was complaining about all of the LARGE bugs like moths etc flying around the TV at night. Wondering where they were coming from, I looked but couldn't find any obvious entry.
I stumbled upon the issue a few days later. We were shopvac-ing the french drain of bugs/spiders as well as the ceiling joists in the basement. When I got to one of the windows, I saw one of those stink bugs crawling from the top of the one window. Turns out the builder left a 1 1/2" gap at the top of both windows! The siding actually came down far enough to where the issue was obfuscated. So for 10ish years, a nice large gap was above both windows. No wonder there were so many spiders and bugs in the house! How the previous owners didn't see that, I'll never guess.
Anyway, I fixed them with 10 bucks' worth of PT wood and caulk. I placed the PT on the outside, caulked, and done.
Why not add wood framing around the window. PT or otherwise to fill in the gaps either on the inside or out. Preferably keeping the elements from entering the house from the outside is preferable but it depends on the situation. A similar framing on the inside should be done as well to complete the seal and can help dress up the window to boot :)
brockmiera 02-14-2013 11:58 AM
I suppose I could do that. Right now the windows are just below my brick and encased in concrete on all sides. I dont know where I would put wood if I decided to go that way.
dengle 02-14-2013 07:41 PM
If you can, take a picture of the inside and outside so we can better provide suggestions. Depending on how big the gap is, perhaps a proper-sized window is in store or potentially taking the window out and inserting a frame of some type to fill in the gap.
brockmiera 02-16-2013 10:16 AM
2 Attachment(s)
Ok heres those pictures.
Joe Carola 02-16-2013 06:57 PM
Are any of these windows going to be in the bedroom ?
brockmiera 02-16-2013 07:29 PM
Nope. No bedrooms at all. Until we sell of course
md2lgyk 02-16-2013 09:50 PM
What exactly does that mean? You can't call a basement room a bedroom without a proper egress window.
cleveman 02-16-2013 11:05 PM
I don't know how many windows like this you have, but it might be worth replacing them for $50/shot.
The window bucks are doing you any good. I would look to get a window which is 1/2" smaller than the opening. Then you fit the window in the opening on 1/4" spacers and put a screw or two in each side jamb. I've also done it without screws.
Then you loosely fill the perimeter with fiberglass and put the foam caulk backer rod on both the interior and exterior. You can caulk over this on the exterior and finish the interior to your taste.
If you don't want to replace the windows, take them out and build a window buck which will leave you with the 1/4" all around space.i
Joe Carola 02-17-2013 12:22 AM
Explain that please.
brockmiera 02-17-2013 12:33 AM
I just need to know how to seal windows from the outside. I was asked for pictures and ive provided them. We will install a proper egress window ina couple years when we sell. Can you add any insight?
747 02-17-2013 01:49 AM
You caulk a window from outside. Inside WINDOW foam. Not just any foam. WINDOW.
md2lgyk 02-17-2013 07:14 AM
Why would you install an egress window and then sell?? Unless you have a walkout basement, it will be an expensive project (think $5,000 or more). Unless you also go ahead a finish a bedroom down there, you'll never add that much value to the house.
