Basement Window Well Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 12:30 PM   #1
Unhappy
I have a basement window well that fills with water during a heavy rain. The water tops the window. I do not need the window. Can I glue a 3/4" piece of plywood over the outside of the window and then fill in the well with dirt? What adhesive should I use?
TonyTeso
TonyTeso is offline   Reply With Quote
Old 03-20-2011, 04:09 PM   #2
Rewards Points: 5,336
TonyTeso
I'd correct the reason the window well is filling up and leave the window alone.
Are gutters over flowing into the well? Is the grading incorrect? Are the leaders too short?
You need to keep the water away from the foundation.
Ron
Old 03-20-2011, 04:41 PM   #3
joed's Avatar
Rewards Points: 12,850
The well should have a drain in the bottom draining down to the weeping tile system.
Old 03-20-2011, 05:05 PM   #4
I am selling the house and want to list it soon. There is no other water problem. Cellar is dry except for this one well. There may be grading issues but I have neither the time nor the money to regrade. Looking for a quick and simple solution.
Old 03-20-2011, 05:21 PM   #5
concretemasonry's Avatar
Rewards Points: 2,608
Mortar in glass blocks.
That will be cheap and avoid the necessary grading and leave that part to the new owner.
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
TonyTeso (03-20-2011)
Tags
basement , waterproofing , window
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 09:21 PM
Basement window replacement Atskodinski Building & Construction 9 03-21-2011 03:26 PM
How to make basement window sills + wall shelves braverichard Carpentry 15 08-27-2010 09:14 PM
Basement window brand recommendations. tigereye Building & Construction 1 08-21-2009 06:07 AM
Basement Moisture problem jimdd Remodeling 1 07-22-2008 02:48 PM
