-   -   Basement Window Well Problem (http://www.diychatroom.com/f19/basement-window-well-problem-98979/)
TonyTeso 03-20-2011 12:30 PM
I have a basement window well that fills with water during a heavy rain. The water tops the window. I do not need the window. Can I glue a 3/4" piece of plywood over the outside of the window and then fill in the well with dirt? What adhesive should I use?
TonyTeso
Ron6519 03-20-2011 04:09 PM
TonyTeso
I'd correct the reason the window well is filling up and leave the window alone.
Are gutters over flowing into the well? Is the grading incorrect? Are the leaders too short?
You need to keep the water away from the foundation.
Ron
joed 03-20-2011 04:41 PM
The well should have a drain in the bottom draining down to the weeping tile system.
TonyTeso 03-20-2011 05:05 PM
I am selling the house and want to list it soon. There is no other water problem. Cellar is dry except for this one well. There may be grading issues but I have neither the time nor the money to regrade. Looking for a quick and simple solution.
concretemasonry 03-20-2011 05:21 PM
Mortar in glass blocks.
That will be cheap and avoid the necessary grading and leave that part to the new owner.
