Basement Window Recessed In Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 09:22 AM   #1
Basement window recessed in foundation
Hey everyone. I just joined up in hopes of guiding me through my basement finishing project in which I have hit a wall (pun intended).
So, I replaced the basement windows in the existing foundation wall. I then built the new basement walls which are obviously out further than the actual window. I set the wall so the front is 12" from the foundation wall due to a lot of uneven floor space so between the distance from the front of the new wall to the front of the new window I have approx 12".
The question is, how do I finish this off. I need to run finish work from the new wall opening to the window. Also, a HUGE concern of mine is sealing off the space behind the wall. I do not want air to flow from the window behind the wall. It will basically be a big air cavity.
I also have a couple other troubled areas which I will post some pics of later.
Last edited by Freaka; 11-09-2008 at 10:11 AM. Reason: Wrong distance. Changed from 24" to 12"
Freaka is offline   Reply With Quote
Old 11-09-2008, 12:28 PM   #2
Rewards Points: 162
Can you frame drywall returns from the new wall to the new window?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 11-09-2008, 01:25 PM   #3
I'm not sure how I would frame it. . I'm a complete novice. Although I shouldn't say that because so far I've framed, run wires and hung drywall basically by myself. It's the tricky stuff like this is where I stink it up.
Anyway, I suppose it's possible.
Old 11-09-2008, 06:25 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Basically, frame a window-sized rectangle and hang it from the ceiling, tight against the outside wall. Seal any irregularities with caulk. It may help to run a couple of horizontal pieces between the rectangle and your new wall. Then just cover the "tunnel" with drywall.
Tinstaafl is offline   Reply With Quote
Old 11-09-2008, 07:15 PM   #5
All you really have to do is frame off of the Pressure Treated window opening in your foudation wall to your existing wall you just built 12" away. Obviously you have to make your window opening in your newley framed wall level to the pressure treated boards around your foundation window opening. all you basically have to do after that is add nailers on the flat in from one side to the other to install your sheet rock . As for the air flow. How would you get airflow back there in the first place if everything is sealed?
kevin211mvd is offline   Reply With Quote
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 10:21 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
Basement window repair/replacement champers General DIY Discussions 7 08-19-2008 11:14 AM
Window in Basement almostdone Building & Construction 6 02-29-2008 12:43 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
