Basement Window - Insulation/Replacement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2009, 09:57 PM   #1
Rewards Points: 502
This is my first house with a basement. The 7 windows in the basement are the original single pane windows.
I'd like to replace them with something that is better insulated and secure so as to reduce the risk of someone breaking in the house via the windows.
I don't want to do blocks. I want to be able to open the windows, and remove at least one of them to get long items in/out.
What recommendations are there?
Basement Window - Insulation/Replacement?-img_3197.jpg
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-30-2009, 03:30 AM   #2
Rewards Points: 5,336
You will get better insulated windows with just about any replacement window with insulated glass. If you want security, get an alarm or bars on the window. There are no windows that will accomplish that task.
Ron
Old 01-30-2009, 06:44 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
While you can get high impact windows that are used in areas with coastal storms,Ron is correct for break and entry protection an alarm or security bars are a better bet.Security bars give me concern however because they can also trap you in,in an emergency
Tom Struble is offline   Reply With Quote
Old 01-30-2009, 11:03 AM   #4
Rewards Points: 562
Make at least a couple of those egress windows. Hope the day never arrives you NEED them,,,but will be forever wishing you did IF so and didnt have them!!
4just1don is offline   Reply With Quote
Old 01-30-2009, 11:43 AM   #5
Rewards Points: 1,910
As far as insulation goes you'd get a lot more bang for your buck by insulating the walls and rim joist areas. Then, if you've still got enough $ go for insulated windows too.
And I second having egress windows - check your local requirements.
Old 01-30-2009, 12:08 PM   #6
A high-rise student housing building I was in decades ago had a problem with thieves smashing windows to get into units on the ground floor. To fight this they installed bars that were released by a single handle on the inside so we could escape in an emergency.
Of course any thief who knew that could have smashed the window through the bars, reached in and turned the handle. I guess they were mostly for show.
An unexpected thing happened. One thief used the bars to climb up to a second story window and rob a unit above me. Naturally that window was unlocked because they were on the second floor. I guess they walked around until they saw an open second story window and climbed on in. They had to tell people on the second floor to start locking their windows.
scowl is offline   Reply With Quote
Old 01-30-2009, 04:24 PM   #7
Rewards Points: 502
Thanks for the pointers.
Since we do plan on finishing the basement in the future, I do plan on making at least one of the windows a 2nd point of egress for safety reasons. I have a backhoe and other equipment for removing the dirt and backfilling, so the cost will just be in materials for me.
I've been trying to figure out how to insulate the rim joists. SHould I just put up styrofoam board or is there a better solution?
The basement is ~30' x 50'.
-Andrew
DIY hobbiest
Old 01-30-2009, 05:21 PM   #8
I replaced 3 single pane windows, basement door & added fiberglass insulation around the rim joist. My basement temp went from 45-50 to 55-63. 1st floor is much warmer too
I plan on building windows over the basement window wells
Partially to keep leaves out, partially to add another layer of glass as insulation. No plans on finishing the basement, at some point it may become a wreck room when my son gets older
Old 01-30-2009, 05:43 PM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
if your looking for an egress window try this product, I have installed about fourteen of these units over the years and never had a problem.
they also have a grill cover system that covers the well so leaves and children wont fall into the well, and light enough foe a child to lift for escape. Hope this helps. BOB
http://www.basementsystems.com/basem...indow_well.php
Old 01-31-2009, 12:09 AM   #10
Learning by Doing
Leah Frances's Avatar
I just replaced 14 basement windows. After the last ones went in the basement and first floor warmed up. We selected an Atrium basement slider.
I picked to do windows before insulation because the old windows were SO leaky. Unfortunately, now my window sills look so BAD against the new windows I'm going to HAVE to paint.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 09-03-2014, 05:56 PM   #11
Basement windows
Hi Andrew,
Did you still keep those single pane pull-in basement windows? I need one to fix my basement badly. If somebody has one or more, I'd like to buy them.
Regards.
James
east8829 is offline   Reply With Quote
Old 09-04-2014, 08:39 AM   #12
Rewards Points: 660
Try Craigslist because you would need a time machine to get these windows.
B
Beepster is offline   Reply With Quote
Old 09-04-2014, 11:07 AM   #13
MarginallyQualified
Rewards Points: 2,464
Since we do plan on finishing the basement in the future, I do plan on making at least one of the windows a 2nd point of egress...
Absent that sort of work going on in the room
or some real damage ... I say leave well enough alone.
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 09:21 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 06:15 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
Window in Basement almostdone Building & Construction 6 02-29-2008 11:43 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
