Old 11-02-2008, 02:12 PM   #1
basement window
Hi I Have A Basement Window A Grad Of Out Side Ground. I Think I Will Fill It In But How Would I Go Adout Doing It Rebar,cement Or What
doo-man23@comcast.net is offline   Reply With Quote
Old 11-02-2008, 02:18 PM   #2
basement window
Huh?
You have a basement window... that you want to install into an existing hole?
You want a basement window where there currently is no opening?
Sorry I can't make sense of your post.
Reilley is offline   Reply With Quote
Old 11-02-2008, 02:27 PM   #3
basement window
No Sorry But The Window Is There But No Good Taking It Out And Look At It The Sill Is Groud Level Water May Get In So Like To Filling It Up With Some Cement 6"and Rebar So It 6"higher Then Out Side Ground And Then Put New Smaller Window In
Old 11-02-2008, 03:02 PM   #4
basement window
You can just use a concrete ready mix for the job. You really don't need rebar for this application, but you can use it if you like.
Ron
Old 11-02-2008, 03:52 PM   #5
basement window
Easier to dig out the ground than to cement it up and put in a smaller window.
Plus if the window is in a bedroom and is large enough you can count that as a bedroom if you ever sell your house. If you make it smaller then you might have to subtract a bedroom if you sell it. Most code has a requirement for the size of emergency access.
Think this out before you proceed.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-02-2008, 04:18 PM   #6
basement window
I agree. This is what window wells are for.
Bedroom egress and natural sunlight are two reasons why larger is better when it comes to basement windows.
Old 11-02-2008, 04:30 PM   #7
basement window
I have a similar problem and I plan to replace the window with glass blocks. My workshop is there, so it won't be a bedroom!
Old 11-02-2008, 04:33 PM   #8
basement window
No This Is In A Garage/workshop
Old 11-02-2008, 04:48 PM   #9
basement window
Still it is easier to just dig down a few inches than to pull all this out and cement some more in. It is not uncommon to have leaks at seams so you might have the same issue down the road. Just a few minutes with a shovel should fix this issue. Or if it's hard soil then even a few hours which would be a lot less time than the other option, not to mention a lot cheaper.
Then again I am a fan of windows. I like natural light and the vitamin D that comes with it.
Plus I have an aversion to work.
Basement Window leaking suze0220 General Discussion 8 08-06-2011 10:21 PM
Basement window repair/replacement champers General Discussion 7 08-19-2008 11:14 AM
basement window replacement ponch37300 Building & Construction 3 08-12-2008 04:58 PM
Window in Basement almostdone Building & Construction 6 02-29-2008 12:43 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
