Basement Waterproofing And Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 01:52 PM   #1
Basement Waterproofing and window
We are planning on adding a baseboard drainage system and an egress window in our finished basement....should one be done before the other?
JohnKonii is offline   Reply With Quote
Old 06-15-2011, 04:18 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Don't waste money on a baseboard ststem if you don't have a problem. - Water in soil moves up, down and laterally, so obviously a drainage system at or below the bottom of the footings is many times more effective and can even lower the humidity in the basement.
If you don't have a problem, don't worry about the drainage system now.
An egress window does not require attacking the lower part of the basement if it is put in according to code height requirements.
Dick
concretemasonry is online now   Reply With Quote
Old 06-15-2011, 07:44 PM   #3
Oh we have a problem! LOL
There is tiling outside but its VERY VERY old and no longer effective apparently. Redoing that is not an option due to I am not willing to redo the ridiculous amount of landscaping around the house. Keep telling hubby it would be easier to just move! LOL
Old 06-15-2011, 09:08 PM   #4
Concrete & Masonry
Rewards Points: 548
I'd consider doing them at about the same time, if it's feasible financially. If the egress window hole is cut in the foundation, and you wait to install the window, the hole makes a great way to get the sections of concrete floor out and the new concrete & other materials in w/o tracking it all through the house. Otherwise, neither of the projects should have much interference, if any, with the other.
jomama45 is offline   Reply With Quote
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Question about window companies... bcbud3 Remodeling 3 06-11-2010 12:22 PM
What Waterproofing Methods Work? HornOfGabriel Building & Construction 4 09-17-2009 06:16 PM
Waterproofing a shower window seacuke23 Tiling, ceramics, marble 3 08-24-2009 01:20 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 09:19 PM
