Basement Waterproofing Coating - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 01:35 PM   #1
I am building a house with a walkout basement made from concrete blocks (all cells are filled with concrete). I have parged the exterior of all three walls that will be underground with Quikrete Quikwall surface bonding cement, which Quikrete says is a waterproof coating, on top of this I will place 15mil plastic. Do you think I need to add an additional waterproofing coating on the exterior of the Quikrete, If so are there any waterproofing coatings available for DIY use? (PS - there will be an exterior foundation drain to daylight).
i_need_help is offline   Reply With Quote
Old 04-05-2011, 04:05 PM   #2
Rewards Points: 508
Here are a couple of different ideas for the below grade portion of your basement walls:
Dimpled membrane:
http://www.cosella-dorken.com/bvf-ca...roducts/ms.php
http://www.superseal.ca/dimpledmembrane.html
Peel and stick:
http://www.dhcsupplies.com/store/p/1...-30-x-50-.html
http://www.cosella-dorken.com/bvf-ca...fing/index.php
benjamincall is offline   Reply With Quote
Old 04-05-2011, 04:11 PM   #3
Rewards Points: 4,644
IF quikcrete sez it & an apron/vest store sold it, you'll have done SOMETHING ' so wait for the pain both of what's-'is-name's ( ben's ) links are good - we use 'em but NOT the peel/stick stuff,,, we prefer to spray polymer & rubber modified asphalt emulsion then protect w/dimpleboard.
Waterproofing before remodeling in basement? Peterbay Remodeling 8 11-14-2016 07:03 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
basement waterproofing nlexi912 Building & Construction 6 12-31-2006 11:27 AM
