-   -   Basement Waterproofing Coating (http://www.diychatroom.com/f19/basement-waterproofing-coating-100633/)
i_need_help 04-05-2011 01:35 PM
I am building a house with a walkout basement made from concrete blocks (all cells are filled with concrete). I have parged the exterior of all three walls that will be underground with Quikrete Quikwall surface bonding cement, which Quikrete says is a waterproof coating, on top of this I will place 15mil plastic. Do you think I need to add an additional waterproofing coating on the exterior of the Quikrete, If so are there any waterproofing coatings available for DIY use? (PS - there will be an exterior foundation drain to daylight).
benjamincall 04-05-2011 04:05 PM
Here are a couple of different ideas for the below grade portion of your basement walls:
Dimpled membrane:
http://www.cosella-dorken.com/bvf-ca...roducts/ms.php
http://www.superseal.ca/dimpledmembrane.html
Peel and stick:
http://www.dhcsupplies.com/store/p/1...-30-x-50-.html
http://www.cosella-dorken.com/bvf-ca...fing/index.php
stadry 04-05-2011 04:11 PM
IF quikcrete sez it & an apron/vest store sold it, you'll have done SOMETHING ' so wait for the pain :yes: both of what's-'is-name's ( ben's ) links are good - we use 'em but NOT the peel/stick stuff,,, we prefer to spray polymer & rubber modified asphalt emulsion then protect w/dimpleboard.
