Old 02-14-2011, 04:49 PM   #1
Basement water proofing
I hope this is the right forum for this ?
I live in the Detroit area where some homes are very close together perhaps
a driveway's width plus maybe 18 inches .
The problem I have is the space between both homes is cement wall to wall.
Now when it rains heavy water flows towards my home and then seeps down
along the wall to the basement where it seeps into my basement not a whole lot but enough to be a pain in the $%#, The walls are reg. cinder block. I can't afford to have my neighbors drive tore up for the amount of water on the floor.
I do recall years ago water proofing companies used to advertise using a
pressure like system where as they would pump tar against the homes basement wall and this would seal up any small leakages
Is this possible to do ? Would this be a way to go, if it is still available ?
Has anyone tried this with success ?
Thanks Robut,
robut is offline   Reply With Quote
Old 02-14-2011, 04:58 PM   #2
Another option you could do if you do not want to destroy your neighbor's drive way would to seal the walls with drylock paint and put in a french drain system with a sump pump in the basement. That would require digging out your basement floor along the perimeter our your basement.
MBatson is offline   Reply With Quote
Old 02-14-2011, 05:14 PM   #3
good luck on the drylocking paints,,, they work ONLY if you're selling the house in dry weather,,, any wtr & you'll see wtr again,,, next time you walk by the display in your apron/vest store, look the other way,,, the only people who recommend that stuff either sell OR make it
the mtl you're trying to place is ' bentonite slurry ' - expansive clay mixed w/water [ think kitty litter ],,, ck the yellow pages for soil cement & see if 1` of those guys can help,,, caution - bentonite injections isn't guaranteed to catch 100% of the area.
if dick comes around, he'll mention thoro - good products for exterior use,,, ps - that's not him in ernie ervin's car no matter what he sez
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 02-14-2011, 05:15 PM   #4
Hey!, I forgot about the drylock paint, this may be a way to go??
Old 02-14-2011, 10:16 PM   #5
drylock is like a bandaid-it covers up the symptoms, and does nothing to solve the issue at hand. use at your own risk
federer is offline   Reply With Quote
Old 05-01-2011, 04:33 PM   #6
Wire Chewer
Red Squirrel's Avatar
I would try to run a line of tar or some other waterproof product along the house/driveway corner. Or maybe some kind of flashing. Maybe even some caulk, though you'll probably have to re-apply it often, it cracks in winter.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
painting brick on top of existing paint / water proofing basement 2md Painting 8 12-14-2010 11:11 AM
water comes down basement walkout stairs carriepartlan Building & Construction 1 07-09-2009 07:13 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Controlling Water in basement greger Building & Construction 3 06-16-2008 06:56 PM
