Old 11-02-2009, 11:26 PM   #1
Default Basement water leaking issue
I just started finishing my basement using a ramset with 1 1/2 inch nails securing the sill plate to the floor. I have never had water in my basement until I started framing. I noticed large puddles of water seeping through the floor. I saw no water seepage running down the walls. Does anyone have any ideas on where this is coming from? Any suggestions on fixing this?
gierkin is offline   Reply With Quote
Old 11-03-2009, 05:16 AM   #2
it sounds as if you're experiencing the effects of hydrostatic pressure,,, wtr's build up outside the fnd walls &, while trying to seek its own level, found some crks in your bsmt's floor.
usual suggestions of downspout leader drains & positive grading will help but not resolve the issue,,, IF there's a toe drainage system, it may be blocked,,, if there isn't, you may need exterior excavation to install it,,, may also be possible to resolve by the installation of sump & pump,,, perhaps our w-site diagrams can help.
1 caution - there's NO interior coating ( magic juice - silver bullet ) that'll cure it including ANYTHING from an apron store.
itsreallyconc is offline   Reply With Quote
Old 11-03-2009, 05:42 PM   #3
How do you secure a 2x4 with a 1 1/2"nail?
Ron
Ron6519 is online now   Reply With Quote
Old 11-03-2009, 06:20 PM   #4
(Hydrostatic pressure) This pressure can become so severe as to crack and lift the floor slab. There is a technique that consists of cutting the floor slab 12" from the wall the entire perimeter and remove. Also cut out a spot for a sump pump pit. Dig a trench that drains to the pit and install perforated pipe, install a sump pump that pumps to the exterior. Install waterproof paneling to the walls to extend down to the newly dug trench. Back fill trench with washed rock or river rock. Pour removed sections of slab.
Digging up the exterior to install a new drain tile and water proofing is the most risky application even for the most skilled installer. It is a good way to collapse the basement walls.
izzym is offline   Reply With Quote
Old 11-04-2009, 07:13 AM   #5
that's where the miradrain comes in,,, tuck the 6mil plastic into the exposed m-drain then all collected wtr vapor/liquid must flow into the trench pipe,,, we do exterior work,,, IF the walls're good condition, fine,,, if not, shore up inside under the direction of structural pe,,, better yet, have the INSURED AND LICENSED contractor you hire work w/the pe.
More On This Topic
This is Ben Ingham with Expert Village talking about a walk out basement. Eventually we are going to come in with water and electricity. The only kind the water that we need is for a sink we are not going to put any kind of bathroom or commodes or... Read More »
A wet basement can wreak havoc on a home, resulting in cracks, destroyed possessions and contribute to the growth of unhealthy mold. Follow these quick techniques to safeguard your house against water damage. Read More »
Hi I'm Dough. I work with 20 great guys in Saint Lois at Doug Jenkins Custom Hot Rods. We are going to do some work for you today on Expert Village. Now Mark is removing the windage tray, every engine of various designs has plates installed or trays and... Read More »
This is Ben Ingham with Expert Village talking about a walkout basement. As I was scouting the land, trying to find a place to where to build this. I was looking for land that sloped naturally this way and hopefully even had a drop off where the back of... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The next step in the process was to have the slab poured in the base here and actually I have that as a term key job because it was about 20 yards of concrete and that is more then... Read More »
Basement water heater "discharge line" proper draining ideas/options? ohman Plumbing 5 06-24-2009 03:22 AM
Water leaking into basement through deck john8791 Building & Construction 8 06-19-2009 05:47 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 10:09 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 03:29 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 09:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
