Basement Water Drain Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 09:20 PM   #1
I want to install a drain in my basement floor for a dehumidifier. It runs constantly in summer. Can I drill a hole in the basement concrete floor and just drop the water from dehumidifier down the hole under the house? The secondary question is I have a radon removal system, wondering if a hole messes with the radon system by changing pressure under the house.
mbeds is offline   Reply With Quote
Old 03-28-2011, 05:02 AM   #2
DIY staff
Rewards Points: 7,174
Don't do that!
Buy a condensate pump---little box with a pump inside---pump the water to a sink.---Mike--
Old 03-28-2011, 06:29 AM   #3
Rewards Points: 4,534
as a general rule, mike's right,,, our present furnace a/c exchanger now drips into bsmt floor & same was done in our previous home,,, no radon issues in either BUT sealing the drainline wouldn't exacerbate any radon,,, HOWEVER, be sure you know what you're doing,,, very possible to cause further troubles as per mike.
Old 03-28-2011, 08:19 AM   #4
Experienced
Jackofall1's Avatar
As a young apprentice, years ago, it was my job to make to hole for such a drain, and I don't ever remember being called back to any of the sites to have it changed.
Mark
Old 03-28-2011, 09:36 AM   #5
Rewards Points: 5,336
Does it make sense to introduce water to the under floor environment?
For under $50.00, you can get a condensate pump and 3/8"tubing and run it correctly.
Ron
Old 03-28-2011, 10:00 AM   #6
Experienced
Jackofall1's Avatar
Ron
Isn't that just adding another unnecessary point of maintenance, a dehumidifier may put out a gallon every couple days if that, and its clean water, why not just put it below slab.
Mark
Old 03-28-2011, 10:18 AM   #7
Mark
I live on LI,NY. Prior to fitting the pump, I'd fill the tank in a day during the Summer at a 50% setting on the unit.
I actually have a floor drain and live where the drainage is great(beach sand under 2')
I still prefer the pump.
Other then the initial installation, it's basically maintenance free.
What you do is based on where you live, the soil you have and your comfort level in the basement hole.
Ron
Sump Pump Water Level w/inside Drain Tile scott j Plumbing 1 02-18-2011 11:25 PM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 09:06 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Water in the basement - help! jkrodger Building & Construction 6 03-19-2008 04:25 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 10:19 PM
