Basement Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 05:14 PM   #1
Gail Truitt
Question
Basement water
If I put cement backer board on the first foot of a basement stud wall, when I drywall, to avoid the water soaked dry wall would it work? I would also not put insulation for the first foot.
gailtruitt is offline   Reply With Quote
Old 02-16-2009, 10:40 PM   #2
Rewards Points: 150
Do you have active water problems? Or are you worried about a flood? Water will wick up the backerboard, or just get to the drywall through the high humidity in the air anyways. Don't close up the walls if there's water infiltation, deal with the deeper, undelying problem, such as improper grading of your property, downspouts that release too close, collapsed/clogged footer drain if you can.
johnnyboy is offline   Reply With Quote
Old 02-17-2009, 10:02 AM   #3
Gail Truitt
I am only worried about the power off no one home to start the generator, flood.
I know, get an automatic generator, sorry not enough money, $5k here in IL.
Old 02-17-2009, 10:43 AM   #4
concretemasonry's Avatar
Rewards Points: 2,578
Don't put fiberglass anywhere you think it could get wet or damp. It holds water and will never dry out enough in place.
concretemasonry is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
basement floor water bigboyjoel Building & Construction 1 05-21-2007 05:46 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
