Basement Walls - Finishing Options - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 05:58 PM   #1
basement walls - finishing options
my basement has the 1940's clay block which are in good shape but I'd like to cover them. Have done the stud wall before with plastic behind, then insulate and finish. Wondering about troweling on a cement finish similar to stucco? Glue a backing board to block first then cover or ???
thanks!!
joejess is offline   Reply With Quote
Old 02-22-2009, 08:27 AM   #2
Remodeling Contractor
do a search and read the hundreds of ideas on this subject first. You need to understand a lot more before you are ready to do this project correctly. Handling moisture is your main concern. Your past experience shows you did this all wrong, so study what is already available here.
Read this link 2x3 vs. 2x4 in basement?
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 08:13 PM
What to wash basement walls with before painting/priming? klein Painting 14 07-17-2008 07:40 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 06:31 AM
"floating" basement walls? greg s Carpentry 2 03-04-2005 07:56 PM
