Basement Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 12:57 PM   #1
Basement Walls
Hi,
We've recently purchased a home built in 1910. There was a broken pipe that flooded the basement for 1 day (water was almost 1ft high).
This is how the basement walls are now. I'm not sure if this was caused by the water or not. We're thinking about finishing the basement, but would like to start with the walls first.
By looking at the pictures:
- Do you think this is normal?
- Anything to be worried about?
- How to treat/insulate walls?
- Paint?
Edit: These "deformations" are only seen at the bottom 1/2 of walls. The top seems to be intact, not signs of deterioration.
Thank you.
Basement Walls-001.jpg   Basement Walls-002.jpg   Basement Walls-003.jpg   Basement Walls-005.jpg
AlineR is offline   Reply With Quote
Painting tricky Basement walls. What paint should I use? tw1208 Painting 1 10-12-2012 09:07 PM
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 01:36 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 07:49 PM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
