Basement WAlls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 06:36 PM   #1
Basement wAlls
Be read much about it and wondering what your take is on it.. So I'm going with 2"XPS board on the basement walls. Think I should butt the 2x4's against the foam board or leave the 1" gap people say to do. Also, should I install more insulation in between my studs? Would you?
Stellsbells is offline   Reply With Quote
Old 01-24-2012, 10:40 PM   #2
Rewards Points: 1,092
Yes, covered here a lot. Goo and tape the seams of the foam. NO air space; it induces convective currents, robbing heat. Sure, put something between the studs if your climate calls for a higher R. Use Roxul or something better than fiberglass; it is the worst. Air seal the outer layer, too (google ADA, or airtight drywall approach); goo bottom and top plates, airtight elect boxes, etc. I'll leave the vapor barrier decision to you. I never would below grade. Good luck.
Old 01-24-2012, 11:02 PM   #3
Thanks for the fast reply. Awesome answers. Thanks for your advice. If I have any questions I'll bug ya again.
Old 01-24-2012, 11:43 PM   #4
Do search here. Opinions vary.... so do results. It's always your call. If in doubt, see buildingscience.com, greenbuildingadvisor.com, etc, and hope there is a consensus on your particular issue. Not everything is black and white.
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 09:32 AM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 12:44 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-17-2010 11:35 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
