Basement Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 02:28 AM   #1
Basement walls
I'm going to hire out a contractor to frame walls and finish my basement. However I told them I don't want drywall over the concrete (The concrete cinderblocks are half way from the floor to the ceiling) I actually like the look of the concrete and the 2 tone contrast it will provide when everything is painted. Not only that, it creates a sense of a bigger space.
My question is is this better or worse for controlling humidity?
Thanks!
khaosduke is offline   Reply With Quote
Old 01-09-2012, 07:57 AM   #2
Civil Engineer
Rewards Points: 4,944
Whether or not you frame over the concrete block basement, and whether you choose to install drywall over the framing, has little to do with how humid your basement is going to be. Basement humidity is controlled by the passage of moisture between the outside and the inside of the house. Moisture passage would be affected by the presence of a vapor barrier on the inside or outside of the basement wall, but drywall and framing are not vapor barriers, hence the humidity would remain unaffected by their inclusion/exclusion.
Daniel Holzman is online now   Reply With Quote
Old 01-09-2012, 04:02 PM   #3
Remodeling Contractor
Framing over the walls (lower section) will trap moisture behind the walls if not properly done. (which is about 95% of the time) What climate zone are you in will determine how to do this correctly.
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 09:32 AM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 12:44 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-17-2010 11:35 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
