Basement Wall Questions. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 01:31 PM   #1
Basement wall questions.
I am finishing our basement. The previous owner has framed the basement with 2X4 turned sideways 16"OC. I originally planned on removing the framing and placing 1" XPS against the foundation, then framing with 2x2s. Is this necessary or can I just put XPS between current studs and dry wall on top? We had a few moisture problems which have been corrected so I will replace some small parts of the framing either way.
Thanks,
Ben
Bcoleman6 is offline   Reply With Quote
Old 03-03-2008, 01:59 PM   #2
Rewards Points: 5,336
Where you're located would determine how much insulation you should have. Unless you're in a place that doesn't get too cold, you might be under insulating with the proposed setup.
Ron
Old 03-03-2008, 02:41 PM   #3
That describes my whole house except the attic. The house was build in the 50's so there is 0 insulation in the walls. Previous owner installed aluminum siding so that helps a little.
I am in Kansas so it does get cold, but I really don't want to tear down perfectly good framing if I don't have to.
Old 03-03-2008, 04:10 PM   #4
You don't have to tear it out, just add to it to get the "R" value you need.
Ron
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Advice needed for Basement Wall nh10ring Building & Construction 5 02-08-2008 06:45 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 09:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
