-   -   Basement wall questions. (http://www.diychatroom.com/f19/basement-wall-questions-17959/)
Bcoleman6 03-03-2008 02:31 PM
I am finishing our basement. The previous owner has framed the basement with 2X4 turned sideways 16"OC. I originally planned on removing the framing and placing 1" XPS against the foundation, then framing with 2x2s. Is this necessary or can I just put XPS between current studs and dry wall on top? We had a few moisture problems which have been corrected so I will replace some small parts of the framing either way.
Thanks,
Ben
Ron6519 03-03-2008 02:59 PM
Where you're located would determine how much insulation you should have. Unless you're in a place that doesn't get too cold, you might be under insulating with the proposed setup.
Ron
Bcoleman6 03-03-2008 03:41 PM
That describes my whole house except the attic. The house was build in the 50's so there is 0 insulation in the walls. Previous owner installed aluminum siding so that helps a little.
I am in Kansas so it does get cold, but I really don't want to tear down perfectly good framing if I don't have to.
Ron6519 03-03-2008 05:10 PM
You don't have to tear it out, just add to it to get the "R" value you need.
Ron
