Basement Wall Panels? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 05:29 PM   #1
Basement wall panels?
Hi,
I'm look at a wall panel system as a solution to finish a basement. So far I have found OVRX Barricade wall system 8 x 2 panels - $50 a piece
Can anyone suggest similar, less expensive products?
Shaun
shaun_m is offline   Reply With Quote
Old 01-08-2011, 06:51 PM   #2
Retired from the grind
Rewards Points: 6,652
Foam board, 2x4s and drywall.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
