Basement Wall Ledge Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2017, 11:08 AM   #1
Rewards Points: 2
I want to install a shower in my basement but the external wall has a ledge about three foot up from the floor. It is insulated from the top of the ledge to the joists with blown in insulation and covered in plastic. I really don't want a shelf in the shower. I can't just build a 2x4 wall in front of the ledge wall because I'm limited to space due to the existing shower floor drain. It would have to be moved which would involve concrete work.
DRox62 is offline   Reply With Quote
Old 01-23-2017, 08:41 PM   #2
Registered User
Rewards Points: 5,204
Re: Basement Wall Ledge Framing
----------------Welcome to the forums!--------------------------
Is there room for 3/4" sleepers on the concrete wall with foam board insulation between if it meets your location Energy Code; http://energycode.pnl.gov/EnergyCodeReqs/index.jsp
Gary
Old 01-23-2017, 09:21 PM   #3
Rewards Points: 156
If you want something that will take up a minimum of available space, look at prefab shower units made of fiberglass or acrylic, or shower wall panel kits.
ChuckF. is offline   Reply With Quote
Old 01-24-2017, 02:14 AM   #4
Rewards Points: 60
nice answer "Gary".......
viveksuthar is offline   Reply With Quote
The Following User Says Thank You to viveksuthar For This Useful Post:
Gary in WA (01-24-2017)
My Basement Journey tojo78 General DIY Discussions 3 01-11-2016 03:10 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Framing up a wall in the basement hankscorpio Building & Construction 7 11-28-2012 07:53 PM
Basement wall framing. mlijoi Remodeling 22 11-13-2012 06:20 PM
basement framing and insulating questions around ledge khatz Building & Construction 8 01-02-2012 01:50 PM
