Basement Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 12:10 PM   #1
Basement wall insulation
When installing paper faced insulation between studs do I have the paper facing towards the concrete wall or towards the inside of the basement?
Dman33 is offline   Reply With Quote
Old 02-14-2011, 12:54 PM   #2
Paper always faces toward heat. So in your case it would be toward the inside of the basement. However, not sure if faced insulation is what you want. Might want to do some more researching around this site for how others have insulated their basements. also check out http://www.buildingscience.com/index_html
gilbo125 is offline   Reply With Quote
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 01:36 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
