Basement Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 10:46 AM   #1
I purchased a home with a partially finished basement. The foundation walls are cement block, drain tile in place, with no past or present water leakage problems. The sill boxes have blown in foam. The basement is not much colder than the rest of the house; maybe about 5-10 degrees cooler.
I plan to completely finish the basement, nothing fancy, just make the space more usable by putting up some drywall.
I am looking for some suggestions on what to do with the exterior walls. I may just paint the existing cement block with a waterproofer. If I choose to insulate the walls, what method of insualtion should I use? The floor space is also limited, so I am trying to keep the walls from encroaching on the space as much space as possible.
dnt is offline   Reply With Quote
Old 01-24-2011, 11:13 AM   #2
Jackofall1's Avatar
You may find the attached helpful in making the proper decisions regarding your project, more specifically insulating of your basement walls.
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 12:17 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 12:36 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
