Basement Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 10:55 PM   #1
Hello,
A quick question on finishing my basement wall system. I've already put 1" rigid foam insulation against the poured walls and built 2x4 walls against the rigid foam.
In my basement, the bottom plate of the walls is right up against the foam, but moving up the wall there is anywhere from 1" to 2" of space. I hope that doesn't cause a problem.
According to this site I should use only un-faced batt insulation to finish the walls. My question is, how to keep the insulation in place without the kraft paper?
Chris
turismo8888 is offline   Reply With Quote
Old 01-23-2011, 11:17 PM   #2
The insulation you put up should fit between your studs as long os you put them up 16 on center!!! Do you plan on using a vapor barrier???
If you did 24 on center then i think you can buy insulation that is made for 24 on center. But i would imagine that your studs are 16 on center...
nsanto17 is offline   Reply With Quote
Old 01-24-2011, 01:15 AM   #3
Proper spacing of the studs will allow a friction fit
masterofall is offline   Reply With Quote
Old 01-24-2011, 09:25 AM   #4
Yeah, I used 16 on center.
I'm having a hard time finding unfaced r-13 insulation. Should I just buy the faced king and remove the kraft paper?
Chris
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 01:36 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
