Basement Wall Framing With Baseboard Heaters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 01:58 PM   #1
Basement wall framing with baseboard heaters
I need to put a frame with drywall in me basement on a 4' high concrete wall. Problem is there is plumbing running along the base of this wall with baseboard heaters. The plumbing may be .5" to 1" from the wall.
Any suggestions on how I can get this framed? Will I have to get the hotwater heating and baseboard rads moved out so I can install the framing and drywall?
I have attached a couple of images to show what I am talking about.
Basement wall framing with baseboard heaters-img_1513-1-.jpg   Basement wall framing with baseboard heaters-img_1514-1-.jpg
gregkfraser is offline   Reply With Quote
Old 11-14-2010, 07:54 PM   #2
Rewards Points: 5,336
Disconnect the plumbing, frame the wall and reroute the baseboard pipes.
Ron
Old 11-14-2010, 08:21 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Yes....
Old 11-14-2010, 09:35 PM   #4
Rewards Points: 1,514
You will want the baseboard heaters moved in so the insulated wall is behind them and you are no longer heating up the concrete wall and the outside soil.
AllanJ is online now   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
