Basement Wall Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 08:59 AM   #1
Rewards Points: 242
Basement wall framing
Hey all,
I'm currently in the process of renovating a basement. I've already framed a wall against my foundation, and closed it off with Roxul and vapor barrier. This wall has plumbing pipes running vertically in front of it, so I will be building another wall which will be approximately 6 inches in front of the insulated wall. I'm curious to know if the insulated wall needs to be drywalled or if I need to do anything else to it before framing the wall in front of it and drywalling it. Thanks!
Lemkie is offline   Reply With Quote
Old 03-07-2013, 03:07 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Why did you put Roxul in the wall that you've already framed against the foundation wall?
brockmiera is offline   Reply With Quote
Old 03-07-2013, 03:49 PM   #3
Rewards Points: 242
Because I originally wasn't planning on building a second wall.
Old 03-07-2013, 09:07 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
before building new wall I'd put a layer of plywood or similar ( fireblocking) against the ceiling that butts to the front of the back wall top plate and comes out to the front edge of the new wall for draft stop. then build your wall, that would be a hard wall to firestop otherwise...
hand drive is offline   Reply With Quote
Old 03-07-2013, 09:54 PM   #5
i think the drywall profiles with gypsum board as a new wall partition is a good way for you. I just know this things.
kelly89 is offline   Reply With Quote
Old 03-08-2013, 03:29 PM   #6
Rewards Points: 242
Good idea on the fireblock. I'll be sure to do this.
My question in regards to the walls though are since the wall against my foundation wall is already insulated and vapor barriers, should I put drywall overtop of it or can I just leave it the way it is and build the wall in front of it and drywall it?
There's going to be about a 2 inch gap between the two walls if that makes a difference.
Thanks!
Old 03-08-2013, 09:01 PM   #7
AHH, SPANS!!!
you really only need drywall on the interior surface of the interior wall facing the room.
The Following User Says Thank You to hand drive For This Useful Post:
Lemkie (03-10-2013)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Framing Basement Wall Underneath Beam Micker Remodeling 5 07-31-2012 08:37 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 01:00 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 07:23 AM
