Basement Wall Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2008, 12:31 PM   #1
Hi, im starting to plan to finish my basement. Could someone tell me the proper way to insulate? ive got block foundation, rigid insulation then frame against that ? vapor barrier , frame , them insulate with batts? , no vapor barrier ? 3/4 of basement walls are below grade, with the rear above grade with a walkout door. been in home a year and a half with no water or moisture problems. thanks , chuck
CPETRO is offline   Reply With Quote
Old 02-17-2008, 12:35 PM   #2
The building science foundation has the latest recommendations. I will be going the XPS aginst wall, no vapor barrier or batts route myself. Of course geographical location and moisture issues should be taken into account.
raam is offline   Reply With Quote
Old 02-18-2008, 12:42 AM   #3
xkempx is offline   Reply With Quote
Old 02-18-2008, 12:45 AM   #4
this may help...
framing a basement wall The RyeGuy Building & Construction 7 09-12-2008 11:40 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 11:54 AM
Framing a plumb wall in the basement perpetual98 Building & Construction 6 01-16-2008 08:22 PM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 08:23 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
