Basement Wall Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 05:33 PM   #1
Basement wall framing
I am framing an exterior wall in my basement (against concrete block). Is it necessary touse a top plate when framing or could I just anchor the 2 x 4 frmes to the floor joists? If not, why not?
Thank you!
tsperry is offline   Reply With Quote
Old 04-23-2011, 05:43 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Using a top plate is the preferred method to maintain straight lines and ease of layout for framing.
Not ALL the studs are going to land exactly on a floor joist.
However if you choose to do it that way I don't see any structural issues.
tcleve4911 is offline   Reply With Quote
Old 04-23-2011, 11:58 PM   #3
Registered User
Rewards Points: 4,894
Yes, it is necessary for fire code compliance. If you have a fire start in an electrical outlet in the wall, it could easily and quickly travel to the floor bays above, across the floor and follow a wiring/plumbing hole to the second floor space or attic. Code (minimum) requires fire blocking at wall top plates and every 10' lineally in the wall or behind it; http://publicecodes.citation.com/ico...002_par031.htm
http://publicecodes.citation.com/ico...002_par032.htm
Please check locally with your Fire Marshall or Building Department.
Gary
The Following 3 Users Say Thank You to Gary in WA For This Useful Post:
AndyGump (04-24-2011), sixeightten (04-24-2011), tcleve4911 (04-24-2011)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 07:05 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 09:50 PM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 08:23 AM
