Basement Wall Bottom Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 08:48 PM   #1
Basement wall bottom plate
Does any one know if it is code in Ontario to use a pressure treated bottom plate on basement stud walls when on the concrete slab? There seems to be a lot of opinions on this.
I was thinking of doing this:
  • Concrete slab, then
  • Foam sill gaskit, then
  • 2x4 pressure treated bottom plate screwed into the slab with tapcons, then
  • 2x4 regular second plate on top of that.
Jeff
Jeff0101 is offline   Reply With Quote
Old 01-07-2012, 08:51 PM   #2
Rewards Points: 13,740
Why the second plate? You only need one bottom plate.
Sill seal is fine.
Old 01-07-2012, 09:15 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why would there be more than one opinion?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-07-2012, 09:16 PM   #4
it will get the drywall off the floor a little more, even though I'm probably going to use tyrok as a subfloor. Other than that I just like the arrangement in the basement with a double bottom plate.
Old 01-07-2012, 10:49 PM   #5
Registered User
Rewards Points: 5,516
I'd ask your local AHJ when you apply for the permit to finish the basement. I would add a sill sealer or two beads of caulking between the plates to stop air infiltration to the colder concrete wall. Even air seal the drywall; http://www.buildingscience.com/docum...wall-approach/
Parts of some of your Codes; http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part2.html
http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part3.html
http://www.hpo.bc.ca/files/download/...nsight/BI2.pdf
Gary
Old 01-07-2012, 10:53 PM   #6
Disabled wood vet
titanoman's Avatar
And solid nailing for baseboard.
Old 01-08-2012, 06:25 AM   #7
Framing Contractor
[*]Concrete slab, then[*]Foam sill gaskit, then[*]2x4 pressure treated bottom plate screwed into the slab with tapcons, then[*]2x4 regular second plate on top of that.
Jeff
Simple answer is to call your building department and ask.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-08-2012, 06:35 AM   #8
Depends on what code is for your area
m smith is offline   Reply With Quote
Walkout Basement Wall Problems in NH Sereguial Building & Construction 4 04-18-2011 10:53 PM
cap plate or just top plate for basement wall rdackman Building & Construction 7 03-19-2011 03:12 AM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate. twilightcall Electrical 2 06-29-2008 11:36 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
