Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 07:09 PM   #1
Basement Wall
Hey guys--new here and needs help. I was looking to wall in a corner of my basement for a small bedroom. Basically, there is an existing corner with studs on each side. What I want to do is wall in the other 2 sides to create a 7X7 room, just big enough for a bed. I really am not handy at all and was hoping there was a product or something that would allow me to create these new 2 walls with minimal construction. Even some sort of 2 sided partition might work. Any link or advice you could offer would be great.
Thanks, Dave
davepharmd is offline   Reply With Quote
Old 04-12-2011, 08:48 PM   #2
Registered User
Rewards Points: 526
Check on getting a permit....... my advice. Egress window, walls, heat source, door, ventilation, min. room= 70sq.ft., etc. in case of fire........
Gary
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 06:05 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 09:57 PM
