Basement Ventilation/ Air Flow - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 04:02 PM   #1
Basement Ventilation/ air flow
I just finished my basement and on the final inspecion the building inspector asked about fresh air/ oxygen flow in the basement. The finished are in my basement is completely below grade and has no windows. I did install a "sani dry" system that removes humidity and circulates clean air. Is this enough or do I need to allow "new, fresh" air to come in some way.
J D T is offline   Reply With Quote
Old 11-17-2011, 05:07 PM   #2
Rewards Points: 6,652
Probably not. If the inspector is stating that you need combustion air for the hvac & water heater, your choice is either get direct vent high efficiency, or change over to electric.
Old 11-17-2011, 11:32 PM   #3
Registered User
Rewards Points: 5,216
This is the first time I have ever heard of a finished basement without egress windows approved by an Inspector. Or are there no bedrooms and one exterior (egress) door?
Where are you located?
Gary
Old 11-18-2011, 12:05 PM   #4
Not so new
12penny's Avatar
Rewards Points: 520
Just finished a walk out basement. As I recall, you need a minimum amount of ventilation (fresh air, measured in sq ft of open glass or doorway). Its a percentage of habitable space, though for the life of me I dont remember what it was.
May have something to do with fire.
GBR...must be a ventilation section in the code book.
12penny is offline   Reply With Quote
Old 11-19-2011, 12:56 AM   #5
Registered User
Yes: http://publicecodes.citation.com/ico...9_3_sec003.htm
I’m much more interested in his meeting this, IF it applies: http://publicecodes.citation.com/ico...9_3_sec010.htm
Gary
Basement Foundation LOUSY CARPENTER Building & Construction 1 11-14-2011 01:06 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 10:55 AM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
