Basement Utility Area - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 11:37 AM   #1
Question
Basement utility area
Hi everyone, I frequent these forums and usually find what I'm after, but this one has got me scratching my head, and was hoping someone could provide some insight.
I'm finishing my basement and my plan is to have a larger finished portion (with TV and such) and an unfinished portion (for my workbench and storage). My furnace, water heater and such will be in the unfinished side close to the finished/unfinished partitioning walls.
Here is a rough layout...
My plan is that there would be fiberglass insulation between the studs (paper backing towards finished side), I didn't plan on putting drywall up on the inside of the wall (unfinished side) but maybe using some OSB to support the air return. Should I be worried about anything in terms of a fire risk? The reason I started thinking about this is because I was going to use some of that foil board for the air return and then saw the warnings about do not place near fire source and that got me to thinking... maybe I don't want to burn my house down as part of this project. Should I be concerned about the fiberglass/OSB?
Thanks!
steve533 is offline   Reply With Quote
Old 10-30-2011, 12:05 PM   #2
Rewards Points: 5,336
All I see is a red "X". No layout.
I'd use unfaced insulation. No need for a vapor barrier in the middle of conditioned space.
The furnace and Hot water heater have a clearance restriction around them. For both access and combustion. For walls and ceilings close to these, I'd use 5/8" firecode sheetrock. Away from the area, whatever you want.
Ron
B. Franklin 1759
Old 10-30-2011, 01:33 PM   #3
Originally Posted by shreenmike View Post
If you want really good answers then share some pics and accurate measurement in details.
Looks like you couldn't see the picture either... interesting, shows up for me. Can you see this?
Old 10-30-2011, 01:46 PM   #4
I should be good from a clearance perspective, I've got 3" behind and the minimum is 0", I've got 10" to the left and the minimum is 1".
Old 10-30-2011, 01:49 PM   #5
Are you sure this furnace is installed with the correct clearances? The 3" space seems a little tight. Actually the 10" space looks tight, the 3" space, really tight.
Just checked. Looks okay from this:
install clearances for g40uh in upflow position
UP-FLOW POSITION
Sides 0 in. (0 mm)
Rear 0 in. (0 mm)
Top 1 in. (25 mm)
Front 3 in. (76 mm)
Front (service/alcove) 24 in. (610 mm)
Floor Combustible
Flue 6 in. (152 mm)
Ron
B. Franklin 1759
Old 11-04-2011, 10:36 AM   #6
Rewards Points: 89
Don't forget if any of your appliances use combustion air within that space,unfinished room dimensions need sufficient cubic feet of air for the BTU ratings of these appliances.If not your access doors to the mechanical room will need to be louvred.
spring3100 is offline   Reply With Quote
Old 11-04-2011, 10:43 AM   #7
Rewards Points: 89
Thanks!
I would use ROXUL in the Basement,it is moisture and mold resistant,and BONUS... a batt for 3 1/2 inch,16 on center boards gives you R-15,versus R-13 for icky fiberglass.
Tags
basement utility
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
basement utility sink install bjkPoker Plumbing 2 03-18-2008 07:12 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
