Basement Support Column Is Bending - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 05:14 PM   #1
Basement support column is bending
I have a 4 inch diameter steel basement support column that is 9.5' tall. It looked like it was bent so I ran a plumb line from the top of the column and it landed 3 inches away from the base. So there are 3 inches of flex in the column. Is this a problem or will the steel be able to handle it?
Nagarjuna is offline   Reply With Quote
Old 06-09-2011, 05:26 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture---is it bent or simply installed out of plumb?? Big difference---
Old 06-09-2011, 05:28 PM   #3
Framing Contractor
Rewards Points: 96
If it is bent, that is a major problem and needs immediate attention. If it is leaning, that can be a problem too, but is much easier to remedy.
sixeightten is offline   Reply With Quote
Old 06-09-2011, 05:48 PM   #4
Attached a photo
I think it was installed out of plumb since the lean is consistent throughout the length of the column.
Old 06-09-2011, 06:15 PM   #5
Framing Contractor
Rewards Points: 96
If the top is not welded, you may be able to move it over, depending on which way the beam is running. The bottom can be move, but it will require removing some concrete. I would be concerned about that.
Old 06-09-2011, 06:35 PM   #6
AfterDinnerDIY.com
I completely agree. Moving the column is a difficult task for the average person. I would tend to get some assistance on this one.
AfterDinner is offline   Reply With Quote
Old 06-09-2011, 06:41 PM   #7
Rewards Points: 5,336
How old is the house?
Is this an original pole in it's original place?
Ron
B. Franklin 1759
Old 06-09-2011, 06:47 PM   #8
The house is about 30 years old. The column is original.
Old 06-09-2011, 07:11 PM   #9
DIY staff
I doubt if the safety of the house is compromised. Just some damn sloppy craftsmanship there.
If there is no sign of the beam itself shifting I believe you are good.
Old 06-09-2011, 07:41 PM   #10
Rewards Points: 4,450
SPEAKING OF SAFETY, aren't those pipe columns supposed to be conc filled to resist fire ? they are also supposed to be installed on individual foundations, NOT on top of the bsmt floor
at least they were in the houses i built
Old 06-09-2011, 09:16 PM   #11
Framing Contractor
Rewards Points: 96
Not sure where you built, but most times they are set on footers that are just below the basement floor. You can see by the pic that the flange is covered by the floor, and it is not sitting on the floor. Never heard of any of them being filled. Maybe commercial or maybe if your using helical piers.
Old 06-09-2011, 10:48 PM   #12
Any support posts I buy now are concrete filled from the steel yard. Most of the ones in the houses I've worked in, which date from the '20's to the '60's, are hollow.
Ron
B. Franklin 1759
Old 06-10-2011, 11:51 AM   #13
Concrete & Masonry
Rewards Points: 470
Hopefully you can plumb the post where it meets the beam at the top. May not be an option though depending on which way it's leaning. As Mike said, it's just plain sloppy workanship, and I don't think there's any structural reason it's leaning.
As for concrete filled posts, I haven't knowingly seen one before. The posts we use don't even have an allowance to fill them. Sounds like a good concept though..........
jomama45 is online now   Reply With Quote
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 08:11 AM
Basement stair support posts alecmcmahon General DIY Discussions 4 11-26-2010 10:33 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Drywall over protruding support column toocheaptohire Building & Construction 12 03-28-2009 06:28 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
