-   -   Basement support column is bending (http://www.diychatroom.com/f19/basement-support-column-bending-107182/)
Nagarjuna 06-09-2011 05:14 PM
I have a 4 inch diameter steel basement support column that is 9.5' tall. It looked like it was bent so I ran a plumb line from the top of the column and it landed 3 inches away from the base. So there are 3 inches of flex in the column. Is this a problem or will the steel be able to handle it?
oh'mike 06-09-2011 05:26 PM
Post a picture---is it bent or simply installed out of plumb?? Big difference---
sixeightten 06-09-2011 05:28 PM
If it is bent, that is a major problem and needs immediate attention. If it is leaning, that can be a problem too, but is much easier to remedy.
Nagarjuna 06-09-2011 05:48 PM
Attached a photo
1 Attachment(s)
I think it was installed out of plumb since the lean is consistent throughout the length of the column.
sixeightten 06-09-2011 06:15 PM
If the top is not welded, you may be able to move it over, depending on which way the beam is running. The bottom can be move, but it will require removing some concrete. I would be concerned about that.
AfterDinner 06-09-2011 06:35 PM
I completely agree. Moving the column is a difficult task for the average person. I would tend to get some assistance on this one.
Ron6519 06-09-2011 06:41 PM
How old is the house?
Is this an original pole in it's original place?
Nagarjuna 06-09-2011 06:47 PM
The house is about 30 years old. The column is original.
oh'mike 06-09-2011 07:11 PM
I doubt if the safety of the house is compromised. Just some damn sloppy craftsmanship there.
If there is no sign of the beam itself shifting I believe you are good.
stadry 06-09-2011 07:41 PM
SPEAKING OF SAFETY, aren't those pipe columns supposed to be conc filled to resist fire ? they are also supposed to be installed on individual foundations, NOT on top of the bsmt floor :no:
at least they were in the houses i built :thumbup:
sixeightten 06-09-2011 09:16 PM
Not sure where you built, but most times they are set on footers that are just below the basement floor. You can see by the pic that the flange is covered by the floor, and it is not sitting on the floor. Never heard of any of them being filled. Maybe commercial or maybe if your using helical piers.
Ron6519 06-09-2011 10:48 PM
Any support posts I buy now are concrete filled from the steel yard. Most of the ones in the houses I've worked in, which date from the '20's to the '60's, are hollow.
jomama45 06-10-2011 11:51 AM
Hopefully you can plumb the post where it meets the beam at the top. May not be an option though depending on which way it's leaning. As Mike said, it's just plain sloppy workanship, and I don't think there's any structural reason it's leaning.
As for concrete filled posts, I haven't knowingly seen one before. The posts we use don't even have an allowance to fill them. Sounds like a good concept though..........
